04-06-2019
10:42
11:08
04-06-2019
10:42
11:08
I have charged my Fitbit and have had a black screen for about 4 days now? I cannot get it to do anything.
Moderator edit: subject and removed personal info
Hi @Helen11385 Try restarting your Charge 3 several times. If that doesnt help try a Long Restart. If it is still not working try changing the clock face in the app. If you still have problems after trying all of these troubleshoots, please come back here for further assistance.
CHARGE 3 LONG RESTART
Plug the device into the charging cable. While the device is plugged into the charging cable, hold the button down for 15 seconds. Remove your finger from button. Note: Device won't have a smiley face icon and should be off with a black screen. Remove the device from the charging cable. Plug the device into the charging cable again. The smiley face icon appears on the screen.
Helen | Western Australia
Welcome to the Forums @Helen11385 and @NellyG thanks for the input.
I was able to see here that our friend @NellyG provided some instructions in order to fix this display issue. Was this the answer you were looking for? If it was, I recommend marking the answer given as a solution. By doing this, other users with the same inquiry will be able to find a faster response.
Now if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out. 🙂
Hello @AlejandraFitbit , I even called fitbit and nothing i did everything that they said and the warch turns on then it turns off. It only remains on for a few minutes.
@Helen11385 I will flag a moderator to assist you.
@Lawa306 Have you tried all the suggestions in the posts above?
04-09-2019
06:48
10:22
04-09-2019
06:48
10:22
Hi @Lawa306 and @Helen11385 thanks for getting back. Thanks for flagging @NellyG.
@Lawa306 I also think these steps, might help with the issue that you're having with your Charge 3. Please let us know if this worked for you.
@Helen11385 We strive for excellent customer service, and customer satisfaction remains our number one goal. I've checked with our Support Team and apparently they already took your case under their wings. Please keep an eye in your email inbox, you'll get some information about your case.
Let me know if you need anything else.
@YojanaFitbit I've also been experiencing these same issues since last week. I have tried the long restart several times and the screen still stays off.
I'm not able to try changing the clock face. Since the Charge3 is not responding, the app can't find it. When I go to change the face, it tells me I'm not able to do so.
04-11-2019
08:21
09:33
04-11-2019
08:21
09:33
Hi guys, thanks for your participation in the Community and for troubleshooting this display issue by yourselves.
@AmandaSA, since the steps you tried didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
@Helen11385, it's great to hear that you are already working with our support team. In the meantime, let me know if you need anything else.
I will see you around.
Hi Everyone,
I also had the same problem and the same results. Black screen althought the phone is working as such but no display
Please help. My husband hasn’t used this in a long time (and barely used it when he got it). I am wanting him to track his steps now and use it, but all I get is a black screen, with no signs of life. He barely used it, so it isn’t like it was mistreated or misused. Please help. I don’t want to spend more money on something that should still work.
Best AnswerFYI-I have tried all the steps listed already.
Best AnswerMine went black two months ago and have tried all of the above. Even went back to where I purchased it (Best Buy) and they couldn't help.
Best AnswerWhere does it tell you to hold the button down for 15 seconds to get the device to turn on? I wish they had a few simple instructions with the device when you buy it so the set up process in the app is not so tedious. It is syncing now.. Thank you.
Best AnswerI have the same problem. Ive tried both the short 8 second and long 15 second restart. Neither is working. I know the tracker still works because I can see the steps on the app and it does still vibrate when I hit my step goal, but no display. I think this Fitbit is less than a year old too! Very frustrating. Can an admin help here???
