01-16-2020
03:58
17:47
01-16-2020
03:58
17:47
My Charge 3 screen is almost full black. Only the bottom side of my screen is visible. Has anyone else experienced the same thing? I have already tried to reset my fit bit but it does not work.
Hello there @Erikjan96, welcome to the Community Forums. Thanks for the details provided and for taking the time to restart your Charge 3 to fix the blank screen prior to contacting us.
Since the restart didn't work, I suggest restarting your Charge 3 using the 15-second method:
In case that neither of the restarts work, please check in your Fitbit app if your Charge 3 is still syncing. If so,change the clock face to a different one to see if this brings back the display. Don't worry if you cannot see anything on the display by now, this process is done through the Fitbit app.
Give this a go and let me know the outcome.
Best AnswerHello @MarreFitbit Thank you so much for your reply. I just tried the 15 second method, changing the clock and checking if its still syncing. This is all working how it should be.
Unfortunatly neither of these things worked tot the display. Is there maybe a way to send some pictures of my display? This because its just half blank. I still can see the bottom of the display/clock but the top display/clock is just blank. So i can check my heartbeat but not the complete time or date.
Hello there @Erikjan96, you're very welcome. Thanks for getting back and trying the steps I recommended above.
No worries about the pictures now, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon! 😉
Let me know if there's anything else I may do to help you.
You're very welcome @Erikjan96! 😉
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
