05-05-2019
07:38
11:08
05-05-2019
07:38
11:08
Just went for a long walk on the beach and my Charge 3 started freaking out. It keeps bouncing between screen wake, the time and blankness. I rinsed it off and dried it but it won’t stop. Any help?
05-06-2019 04:42
05-06-2019 04:42
Hello @VenusShines, thanks for stopping by! Thanks for trying to solve the issue about the screen acting odd. Nice way to go!
From the clock face, swipe to Settings and tap Reboot Device.
If your tracker is still acting odd, follow the restart instructions below.
Give this a go and let me know the outcome.
05-06-2019 17:40
05-06-2019 17:40
05-07-2019 07:26
05-07-2019 07:26
Hello there @VenusShines, thanks for coming back and for letting me know the restart worked.
If your Charge 3 seemed to run out of battery, I'd recommend restarting your device once again. When attempting the restart it, I suggest to let your device into the charger around 20 minutes and then go for the restart.
Please take a look at the help article Why isn't my battery charging? and follow the instructions provide there.
We recommend to charge your trackers via the USB port over a wall adapter. However, it is also possible to charge your Fitbit tracker with a UL certified wall adapter. What may actually cause damage to the tracker's battery (either on a computer or a wall adapter) is the charging time, which if excessive over time may damage the battery and therefore cause quick battery drain or prevent the tracker from charging at all.
Tips to best charge Fitbit trackers are:
For charging purposes, your charging cable can be plugged into any USB power source, including but not limited to:
Let me know if you need anything else!
04-29-2020 13:44
04-29-2020 13:44
Hello, my FitBit Charge 3 is doing the same thing. Flicks/vibrates back and forth from main screen to the 'Screen/wake and Notification' screen. I've rebooted from the screen twice, doesn't work; also plugged it in to restart with the happy face. Neither works. What can i do please?
04-29-2020 14:41
04-29-2020 14:41
