06-05-2021
01:09
07:38
AndreaFitbit
06-05-2021
01:09
07:38
AndreaFitbit
I'm struggling to increase the brightness on my charge 3. I can't do it on the tracker as the brightness is too dim to see what I'm doing. Can I do it through my app as I've looked and can't see how. YouTube is no help only shows you to do on the tracker. Help would be appreciated, thankyou..
06-05-2021 07:42
06-05-2021 07:42
Welcome to the Fitbit Community, @Chel1970. Thank you for letting us know that your Charge 3 brightness is too dim and that you have tried making it brighter through the app.
I would recommend restarting your Charge 3 to make it brighter:
You can restart your tracker from your wrist. Open the Settings app and tap About > Reboot Device.
If your Charge series tracker is unresponsive: .
Your tracker should now work normally. If your tracker still doesn't work after a restart, contact Customer Support.
