11-19-2018
23:10
14:34
11-19-2018
23:10
14:34
I recently bought my Fitbit Charge 3 and 2 weeks later it stopped working. When I looked inside it clearly had water inside, I never swam with it in the pool or sea, I just took regular showers with it. When I first bought the Charge 3 it clearly stated that I can take showers with it.
@Asmaalhouti you need to. contact Customer Support to get a case logged and they will be able to assist your further with this.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
11-21-2018
06:11
08:23
11-21-2018
06:11
08:23
It's great to welcome you @Asmaalhouti and @Tony.r thanks for stopping by.
I am sorry to hear about what happened with your Charge 3. Upon checking with our support team, I was told that you followed our friend's recommendation and contacted them. I know they will be glad to help you out and provide you a solution.
Let me know if you need anything else. ![]()
Hi there. I have a similar issue with my brand new charge 3. I contacted the support team and they are sending me a replacement watch. I just wanted to find out if you received a replacement and if you did, what was the shipping method?( post office or via a private courier service)
Best AnswerHi there. I got my Fitbit charge 3 , 3 months ago and I've experienced the same problem 3 times. Fitbit keeps sending me a replacement but my worry is that once, its out of warranty, what will I do? Clearly there seems to be a manufacturing defect with the charge 3. Every time I ask them about what will happen after my warranty is over, I get a standard response which I think is unfair
Same! I just my replacement like 2 days ago and there seems to be condensation on the inside and it isn’t holding it’s charge. All I have done is worn it while washing my hands. My fiancé’s charge 3 doesn’t seem to have this issue though. Very annoying.
