10-07-2021
13:14
14:45
CindyMFitbit
10-07-2021
13:14
14:45
CindyMFitbit
Can not get to settings on the watch as the screen is blacked out - tried resetting - again can’t see if it took screen is blacked out - does do three blips - tried re attaching it to my phone - sends a four number code to the watch which of course I can’t read cause the screen is blacked out 😢 I’ve gone to help they’ve offered me a discount on a new watch - want to get this one to work if I’m able any suggestions
10-07-2021 14:53 - edited 10-07-2021 14:54
Welcome to the Community Forums @SunsetRunner.
Thank you for the information and for the troubleshooting steps you've followed prior to posting. Please make sure that your Charge 3 isn't in Sleep mode. When Sleep mode is activated take into consideration that the screen's brightness is set to dim. To verify this: Press and hold the button, and swipe left to access the quick settings screen. Tap Sleep is your see the option, to turn it on or off. When you turn off the setting, the icon appears dim with a line through it.
In addition, I recommend performing a long restart. A long restart is different than the basic restart and you can perform it by following the steps below:
On a side note, if you already contacted our Support Team, I recommend to continue working with them since they have already all the details and special tools to continue assisting you.
Hope this helps.
10-07-2021 15:03
10-07-2021 15:03
Best Answer10-07-2021 15:40
10-07-2021 15:40
Thanks for your response @SunsetRunner.
I appreciate for trying the suggested instructions. I'm sorry that you've had this experience with your Charge 3. As you may notice, the only way to complete the set up process is by using the code displayed on the Charge 3, but since it is not lighting up, it won't possible. In case you have any additional questions about the outcome of your case you can contact our team back.
See you around.
Best Answer10-07-2021 19:01
10-07-2021 19:01
Best Answer10-08-2021 08:07
10-08-2021 08:07
How do you get to the sleep setting if you can’t see the screen?
Best Answer10-10-2021 08:07
10-10-2021 08:07
Thanks for getting back @SunsetRunner. Welcome! It's great to see you around @BethWid.
@SunsetRunner Please note that is not possible to send the code to your phone, it sends the code only to the Fitbit itself. I'm sorry for the inconvenience.
@BethWid If the display is just dark or dim, you can try to get the sleep mode by pressing and holding the button, and swipe left to access the quick settings screen. If the display is not turning on at all, I suggest to follow the restart as described here.
See you around.
