09-23-2021
10:56
12:04
CindyMFitbit
09-23-2021
10:56
12:04
CindyMFitbit
My Fitbit is less than a year old can’t read anything on my screen but it’s still working
Moderator Edit: Clarified subject and label
09-23-2021 12:04 - edited 09-23-2021 12:05
Welcome! It's great to see you around @Debbie0106.
Thanks for the details shared on your post. Do you mind to confirm if the display is not turning on at all, or if it is still on but it's dim? In the meantime, I recommend trying the following:
- Restart your Charge 3. For more information, see How do I restart my Fitbit device?
- If the issue persists, try a long restart, it is different than the basic one and you can complete it by following the instructions below:
On a side note, I've moved your post to the Other Charge Trackers board to keep our forums organized.
Hope this helps.
09-26-2021 09:36
09-26-2021 09:36
09-26-2021 10:36
09-26-2021 10:36
@Debbie0106 Thanks for your response and for confirm that the display goes black.
Let's try to change the clock face for testing purposes. You can find the instructions here. If that doesn't work, my best recommendation is contact our Support Team so they can look deeper into the issue and help you with this matter. You can contact them through chat or over the phone. Click here to get connected. Make sure to mention the steps you've followed, so they can help you from there.
See you around.
