01-21-2020
10:58
17:35
01-21-2020
10:58
17:35
Charge 3 display won't respond
01-21-2020 11:10
01-21-2020 11:10
You better start all over.
Best Answer01-21-2020 16:26
01-21-2020 16:26
Hello there @Lindarts, welcome to the Community Forums. Thanks for the details provided about your Charge 3's screen behavior. I'll be glad to help you.
First, I'd recommend to restart your Charge 3 by following the steps in the help article: How do I restart my Fitbit device?
If the restart does not work, please check in your Fitbit app if your Charge 3 is still syncing. If so, change the clock face to a different one to see if this brings back the display. Don't worry if you cannot see anything on the display by now, this process is done through the Fitbit app.
Thanks for your help @SunsetRunner.
Give this a go and let me know the outcome, I'll be around.
Best Answer01-21-2020 16:36
01-21-2020 16:36
I have the same issue with the screen being unresponsive and vibrating, tried the factory restart a couple times with no luck and the Charge 3 bluetooth will not sync or show up so the clock face can’t be changed. Please help!!
Best Answer01-21-2020 16:52
01-21-2020 16:52
Hi there @nadzradz, welcome on board. Thanks for the details provided and for trying to fix your Charge 3's screen.
Since this sounds a bit more serious, I've created a support case on your behalf - you should soon receive an email from Customer Support at the email you used to register with the Community forums. If you have any questions, don't hesitate to let me know
Best Answer01-21-2020 21:04
01-21-2020 21:04
Screen is unresponsive. Vibrates on and off. Please help.!!
Best Answer01-22-2020 03:51
01-22-2020 03:51
Having similar issues - screen unresponsive, flashing between main clockface/settings and vibrating.
Have attempted both the 9 sec and 15 sec restarts, changing the clockface. Clockface changes but issues are still there.
Best Answer01-22-2020 05:52
01-22-2020 05:52
I have tried all the recommend troubleshooting as well. But the problem is still there.
Best Answer01-22-2020 09:37
01-22-2020 09:37
Hello there @Mlomeli25 and @NDbogan, thanks for stopping by and following the tips and recommendations I provided.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Let me know if there's anything else I may do to help you in the meantime.
Best Answer01-22-2020 11:01
01-22-2020 11:01
Thank you ! Looking forward to it.
Best Answer01-22-2020 11:16
01-22-2020 11:16
Anytime @Mlomeli25. 😉
Best Answer01-23-2020 07:19
01-23-2020 07:19
Thank you for all the help!! The Fitbit support team was very responsive. A replacement unit is now being sent to me. Very pleased.
regards,
Miguel.L
Best Answer01-23-2020 11:09 - edited 10-11-2023 08:34
Music to my ears @Mlomeli25! 😀 I'm very happy to hear that our Support Team replaced your Charge 3.
Please don't forget that you can set up your new device on your currently Fitbit account by following the steps below:
