07-13-2020
06:22
08:40
07-13-2020
06:22
08:40
A week ago the device suddenly fails to indicate by vibration the end of the timer, the activity hours. and the 10000 steps. the settings seem to be adequate. (vibration normal) but nothing vibrates.
07-13-2020 09:57
07-13-2020 09:57
Make sure you don't have notifications turned off. Hold in left side button a few seconds; just below 'Screen Wake' is 'Notifications'; if it is gray with a line through it, they are turned off; tap to toggle back on.
Best Answer07-13-2020 22:32
07-13-2020 22:32
Thank you for your quick answer, but it doesn't help. The notifications are activated and it still does not vibrate,
