10-18-2018
01:01
15:03
10-18-2018
01:01
15:03
Hi! I have my Charge 3 for a couple of days now. The first day it was syncing fine and also tracked my sleep.
The last two days he doens't want to sync, it says it did but in the app it says 0 steps, 0 floors, ... (my fitbit shows the right amount). Also the last two nights it doesn't track my sleep anymore, my fitbit says "sleep not tracked".
Anything I can do?
10-19-2018 07:59
10-19-2018 07:59
Welcome on board @Isa95, it's nice to see you around here!
Thanks for taking the time to share all of those details regarding this situation.
In this case, I'd recommend performing a restart on your Charge 3 and please see: Why won't my Fitbit device sync?
You can also find more information about sleep tracking here.
If you happened to loose a night of sleep; note that you can log that night's sleep manually. Please do this so you don't loose any data.
Hope this helps. Keep me posted! ![]()
Best Answer10-19-2018 07:59
10-19-2018 07:59
Best Answer10-23-2018 05:33
10-23-2018 05:33
Hello! Thank you for your answer. I deconnected my Charge 3 and then synced it again with my phone, and now it's working fine.
The only thing that's not working is the calorie and active minutes-count when I swim. When I track my swim with the swim-app, it says I burn 160 calories in 1h30m and it also doens't calculate this in my active minutes. When I add my swim manually, it works fine. Will this be fixed?
Best Answer10-23-2018 10:07 - edited 11-07-2023 07:20
You're welcome @Isa95! I'm glad to hear that you're back on track! ![]()
In addition to completing only a handful of laps or stopping to rest often, inconsistencies in your swim data may be caused by any of the following:
Hope this helps, I'll be around if you need further assistance!
Best Answer05-12-2020 13:09
05-12-2020 13:09
This is in no way helpful because people already know the simple troubleshooting actions. Reason being that fitbit sells defective products, defective software and everybody has already had to troubleshoot Their defective item from no relief from these issues.
I have had three Fitbit charge 3s one was replace via warranty and I still have the same issues with all of them!
