01-17-2019
11:23
13:05
01-17-2019
11:23
13:05
My charge 3 was coming on to show the time when I moved my wrist over to look at it. I haven't changed any settings but it has now stopped, I have to tap the screennor push the button to wake it up. Does anyone know how to cure this, I've already tried a restart on it which didn't work.
01-17-2019 13:39
01-17-2019 13:39
Try holding in the button, sweep left, check the quick settings.
01-17-2019 12:13
01-17-2019 12:13
I have the same problem. Mi e also does not recognize and log runs.
Best Answer01-17-2019 12:16
01-17-2019 12:16
same issue, i can not get face to light up with wrist movement. have to tap 2x - annoying , charge 2 did activate on wrist motion
01-17-2019 13:39
01-17-2019 13:39
01-24-2019 16:00
01-24-2019 16:00
Thanks Rich. Forgot about that functionality!
04-13-2020 23:41
04-13-2020 23:41
Tried holding button and sweeping left. This get me to a screen with "Screen Wake" and "Notifications" neither seems to solve the problem. Any other ideas?? Really need to solve this issue and it sounds like others have the same problem.
09-14-2020 11:22
09-14-2020 11:22
This is very annoying. My Charge 3 stopped showing time when I move my wrist. I've read through all the fixes and although I can get to the Screen Wake screen, toggling or tapping has ZERO effect. I'm thinking my Charge 3 is defective.
Best Answer09-20-2020 09:13
09-20-2020 09:13
Yeah same here, is annoying as the screen wake function won’t activate... no reason for going into this mode either, didn’t change anything... twice in a couple months
