02-24-2021
05:53
07:22
WilsonFitbit
02-24-2021
05:53
07:22
WilsonFitbit
The exercise keeps opening and starting the exercise. This has been happening a lot within the past month. I have tried rebooting the Fitbit both through the 'Reboot' option in the settings and the USB charger method and the issue still occurs.
02-24-2021 07:22
02-24-2021 07:22
Hello @Aviationn, welcome to the community forums! Thank you for the troubleshooting steps you've tried prior to posting!
I suggest you to perform a long restart which is different than the basic restart. For this, please follow the steps below:
Hope this helps!
Best Answer02-24-2021 08:42
02-24-2021 08:42
I have just tried this method of doing a long restart however it does not work. After pressing and holding for 15 seconds all that happens is a smiley face appears and then it goes back to the normal Fitbit clock. I tried doing the long restart method multiple times however there are no vibrations that occur.
Best Answer02-25-2021 05:08
02-25-2021 05:08
@Aviationn, thank you for trying the suggested troubleshooting steps!
Since the inconvenience has persisted, the best way to get help is to contact our Support Team. You can contact them through chat or over the phone. Click here to get connected. Make sure to explain the situation and mention the troubleshooting steps that you've followed.
See you around.
