11-20-2018
18:05
14:34
11-20-2018
18:05
14:34
My Charge 3 was working fine. When I used the stopwatch, it worked fine. After I was done with the stopwatch I could not exit. Swiping in all directions did nothing. The button would not work. It was locked on screen wake screen. Simple restart did not work. A long restart did.
I tested it two more times. Every time I used the stopwatch, it worked but I always ended with a frozen screen wake screen requiring a restart. I am on 1.44.33 firmware. Obviously there are additional bugs requiring attention.
11-21-2018
03:58
08:24
11-21-2018
03:58
08:24
A warm welcome to the Community @Schaferj.
Thanks for troubleshooting this by yourself. Upon checking with our support team, I was told that you have already created a case with them. I know they will be glad to help you out and provide you a solution.
Let me know if you need anything else. ![]()
03:58
08:24
11-21-2018
03:58
08:24
Best Answer11-28-2018 07:49
11-28-2018 07:49
I have not received a reply except one that says a case was opened.
03:33
08:24
11-29-2018
03:33
08:24
Hey @Schaferj, thanks for getting back.
It's weird to hear that our support team didn't contact you back, have you check your spam folder? In the meantime, I recommend trying the following:
Restart:
Long Restart:
Hope to hear from you soon. ![]()
Best Answer11-29-2018 08:24
11-29-2018 08:24
Best Answer10-17-2019 18:07
10-17-2019 18:07
Hello AlejandraFitbit,
Thanks for your response. Before I do this, will I lose my history and my day's steps and other info?
My data is uploaded to my Health Insurance Wellness program, and I need to keep my history because I need to synch it and haven't done so for a while.
Please respond. Thank you.
(Same question for both QuickStart and LongStart methods.
Thank you.
07:12
08:24
10-18-2019
07:12
08:24
It's great to see new faces, @SweeneyJ welcome.
Regarding your inquiry, no, you won't lose your information if you perform a restart and a long restart. After trying these steps, let me know if the problem with the screen is resolved.
I hope to hear from you soon.
10-18-2019 17:28
10-18-2019 17:28
Thank you @AlejandraFitbit
As it turned out, after I started charging the Charge3 (2nd or 3rd time), the device screen unfroze and I did not have to restart it. But I will know that for next time that I won't lose my data.
Thank you.
JS
05:39
08:25
10-20-2019
05:39
08:25
Those are great news, @SweeneyJ.
I am glad to hear that your tracker is now working properly. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up!
Best Answer12-27-2019 15:58
12-27-2019 15:58
I tried all of this my screen still stays black and because my one year is up, they won't replace it, they know of this defect, I am so disappointed in Fitbit
12-27-2019 19:19
12-27-2019 19:19
Best Answer12-30-2019 15:48
12-30-2019 15:48
I have at least Fitbit Charge 2's in my closet because they no longer work. This last year I bought a Fitbit Charger3. Now it does turn on. I used the two strategies mentioned on line an neither works. The screen remains blank. I also used different chargers in case that was the issue. Nothing works. I just get a blank screen. Three or four Fitbits ago I wore a simple Fitbit on a cord around my neck. I stopped wearing it when a lady on the street stopped me and said "Oh' you fall too! I am totally disappointed. I would to return them all for a refund. Then I can buy a pedometer that works. Thanks. Diane Williams
Best Answer04-10-2020 04:35
04-10-2020 04:35
I was told same thing after mines did the same thing twice. This was a defective product from the start. I'm very disappointed my 2 had no problems I jus upgraded to the 3.
Best Answer04-10-2020 06:02
04-10-2020 06:02
