07-26-2019
07:54
10:55
07-26-2019
07:54
10:55
My Fitbit Charge 3 purchased in December 2018 screen shows white lines/gray fuzzy screen - not sure exactly how to describe. I have noticed it also does not hold a charge for long since this happened. I updated, restarted and rebooted the device and nothing has changed. I realize there are some similar posts which I have read and led me to try the reboot.
07-26-2019 07:55
07-26-2019 07:55
07-26-2019 07:55
07-26-2019 07:55
12-14-2019 13:09
12-14-2019 13:09
Am I blind or stupid, but I see no solution here. How do I get in touch with Fitbit other than waiting on Hold on the phone? I sent a DM, and there was no reply. I love my Charge 3 - when it works! There isn't one Fitbit I've had that didn't have issues. It's the holiday season, I'm 70 years old, my husband is having surgery in January. I resent having to take the time to mess around trying to get help from Fitbit for a unit I bought in February, 2019. So frustrated.
04-26-2020 12:16
04-26-2020 12:16
SAME issue, mine from SAME time period. NO fix, throw it in the garbage and buy a new one. This is obviously something they know about and are unwilling to replace mine.
05-18-2020 10:41
05-18-2020 10:41
I pre-ordered my charge 3 when they first came out. About 6 months in it did the same thing. It was still under warranty so they sent me a new one. Now about 6 months later the replacement has done the same thing! Ugh. I'm going to contact them to see if maybe I could get a discount on a new one and get the versa 2. It's very irritating especially since they're so expensive. With the first one the lady I spoke with told me how to shut it down by holding the button for like 30 seconds. My old one wouldn't even do that. I tried it on this one and it starts to do it then restarts. You'll see a bar moving across the screen. I don't know if it actually completes the reboot, but it has no effect on the gray streaked screen. Good luck.
05-18-2020 12:45
05-18-2020 12:45
