10-18-2020 00:11 - last edited on 10-19-2020 11:10 by LiliyaFitbit
My fit bit screen has gone grey with lines.
i have rebooted twice, reset and unpaired settings, I have changed click face all things suggested on other chats Of same issue but nothing is working this watch is not even a year old !
emma
Welcome to the Fitbit Community, @Emma1023456.
I am sorry to hear your Charge 3 screen has gone grey with lines. Thanks for trying to resolve this, I totally understand how you are feeling and I am here to help. Since you've tried to restart the tracker and change a clock face, I would like to confirm if you've tried doing a long restart:
Additionally, I recommend checking if your Fitbit app is updated to the latest version as updates come with new features and bug fixes: How do I update the Fitbit app?
Keep me posted on the outcome.
Best AnswerWelcome to the Fitbit Community, @Emma1023456.
Best AnswerHi @Emma1023456, thank you for your reply.
I am sorry to hear the issue persists, thank you for your efforts. I've sent your information to the Customer Support team so they can get in touch with you and provide further assistance. You should be getting a reply soon.
Let me know if you have any questions.
Best AnswerHi,
My Fitbit has started doing the same thing. It has lines going top to bottom through numbers. I’ve tried all your suggestions, but still not working properly 😞
Best Answerhi there...
I have the same issue and it seemed to occur after the recent software update...in my case the screen is blank. . I tried the workarounds also...
Can you **ahem** the outcome here?
Thanks..
Best AnswerThis recipy does not work. Istead of inventing procedures you should improve the quality of.your Charger 3. Usei a Charger 2 for a year without problemas.
Best AnswerI was having the same problem, but I’ve gone from lines to a completely blank screen. It still syncs with my phone, but I can see absolutely nothing. I’ve reset and updated everything. But still no changes. I’ll try the clock face change, but since I can’t see the screen I’m not holding out hope 😞
Best AnswerMy Charge 3, less than one year old has white vertical lines. Have done the short and long restart, reinstalled and rebooted, nothing appears to fix issue. Please help...
Best AnswerHi I’ve done all that is mentioned. Tried everything and lines are still appearing on my screen. Anymore advice or do I need to buy a new device?
Best AnswerThis reply is for everyone...Contact Fitbit customer support via live messager..If you’re in UK you have a 2 year warranty,if you have grey/lines etc on the Fitbit,no amount of re-setting will work..It’s goosed...you will be offered a replacement or a 50% off new product voucher 👍🏻
