08-15-2021
18:37
04:01
WilsonFitbit
08-15-2021
18:37
04:01
WilsonFitbit
I have a hard time syncing my Charger 3 but after 20-30 minutes it’ll finally sync. Now a new problem has developed and it loses around 6-8 minutes of time between midnight and 8am when I wake up. The incorrect time will continue to slowly drop until I do the morning sync to see how I slept. Then, it’s the correct time. Today I noticed that it is losing time (so far 2 minutes) since it last synced 6 hrs ago. Is the watch battery fading and can it be replaced?
08-16-2021 04:06 - edited 08-16-2021 04:08
Hello @7D-plus. Welcome to the community forums!
Thank you for the detailed information and for the steps you've followed prior to posting. If your Charge 3 is still failing to sync, I'd recommend following all the recommended steps suggested in this help article: Why won't my Fitbit device sync?
I also recommend performing a restart by following the instructions here and a long restart by following the instructions below:
In addition, I'd like to let you know that I'm not sure about what exactly could have caused this inconvenience, but I will suggest taking a look at this other help article to see if some of the instructions could help: How do I change the time on my Fitbit device?
Also, take into consideration that replacement devices are provided for products within the warranty period. For more information, please check: https://www.fitbit.com/global/us/legal/returns-and-warranty.
Hope this helps.
Best Answer08-16-2021 08:31
08-16-2021 08:31
Same thing happened to my Charge 3 in February 2021.
I eventually got it to work again by completely removing all registered devices on my Bluetooth settings on the iphone, deleting the Charge 3 from my account and re-adding it from scratch.
MarreFitbit got me through it at the time.
08-19-2021 06:00
08-19-2021 06:00
@NCavanagh It's great to see you around!
Thank you very much for your great input and for letting us know that those instructions worked for you! I hope you can continue tracking towards your fitness goals.
See you around.
