08-03-2021
14:29
04:28
WilsonFitbit
08-03-2021
14:29
04:28
WilsonFitbit
Anyone having trouble with the step tracking on their Charge 3? Mine stops at 67 steps. Find it most annoying.
Checked the bluetooth and it's on.
Had problems recently that light was dim and then one day it was back to normal. Go figure!
08-04-2021 04:35
08-04-2021 04:35
Hello @Lillepige. Welcome to the community forums.
I'm sorry for the inconvenience and thank you for the information and for the troubleshooting steps you've followed. At this time, I'd recommend performing a restart to your Charge 3 by following the instructions here. If that doesn't work, please perform a long restart which is different than the basic one and you can complete it by following the instructions below:
On a side note, in case your Charge 3 experiences any syncing inconvenience, I'd recommend performing these troubleshooting steps:
Why won't my Fitbit device sync?
For the screen inconvenience, I'd like to let you know that there is a thread that contains tips and suggestions on how to help with dim screens.
Hope this helps.
Best Answer08-04-2021 04:35
08-04-2021 04:35
Hope this helps.
Best Answer08-10-2021 13:17
08-10-2021 13:17
Best Answer08-11-2021 04:26
08-11-2021 04:26
@Lillepige It's been a pleasure!
I'm glad to hear that the instructions worked! I hope you can continue tracking towards your fitness goals!
See you around.
