Charge 3 is not resetting at midnight
My Fitbit no longer resets after 24 hours I also can’t see notifications very dim. Problems came about at same time Fitbit is 3 months old. Will be my last
4 REPLIES 4
Hi there @Ilovelibby12, welcome to the Community Forums. Thanks for the details provided.
If your Charge 3 isn't resetting at midnight, I recommend verifying that your timezone is correct by following the instructions provide in the help article: How do I change the time on my Fitbit device?. Also, try to restart your tracker to fix the screen that is getting dim.
Give this a go and let me know if the issue persists.
I figured it out, Time is correct but watch is still difficult to read.Screen is very light.    Thank You for getting back to me.
You're very welcome @Ilovelibby12. If you want to adjust your tracker's brightness, I recommend swiping left to settings and tap the brightness option. You can select between: Dim, Normal or Auto.
Give this a try and let me know the outcome.
Sent from AT&T Yahoo Mail for iPhone
