03-25-2019
14:45
11:08
03-25-2019
14:45
11:08
I'm in two workweek hustle group challenges that started at the same time in the same timezone but are showing different amounts of steps under my score/stats. My dashboard seems to be syncing, updating and correct but one of the groups shows me as roughly 5000 steps behind.
I've had a look at similar posts but can't seem to fix my problem- any ideas?
I only got this fitbit on Sunday and I'm really hoping this can be easily resolved...
Thanks
03-26-2019 12:33 - edited 09-25-2024 03:08
Welcome to the Fitbit Community @charrm! Thanks for taking the time to look at similar posts, nice way to start.
If your steps aren't syncing to your challenges, below are possible reasons for this issue:
1. Your steps have fully synced to our database but you're not viewing the mobile app dashboard in Live Data Mode. (Live data mode would show the word "connected" under your tracker tile).
2. You manually logged an activity. Steps from manually logged activities do not count toward challenges; only steps recorded by your tracker or MobileTrack are counted toward challenges.
3. You used MobileRun to track GPS data with your app. Only steps recorded by a tracker or MobileTrack are counted toward challenges.
I also recommend waiting 15 minutes after syncing your Fitbit data to see if your challenge updates. For more information about this, check the help article What should I know about Fitbit challenges?.
Hope this helps, keep me in the loop!
07-17-2019 14:20
07-17-2019 14:20
I am having the same problem. My dashboard syncs, but not my workweek challenges. I have tried:
uninstalling the app
restarting my Fitbit
restarting my phone
turning Bluetooth off and on
none of this has worked. I installed the new update to my watch as well. My app is up to date. The challenge is all in the same time zone, no gps or manual steps added.
Is there a fix?
07-17-2019 15:17
07-17-2019 15:17
I am in the same situation, just updated my charge 3 and syncing is working for my steps but not to the workweek hustle. Please help!
07-17-2019 16:07
07-17-2019 16:07
Same issue for me too. It says that I haven’t synced for 7 hours.
07-17-2019 17:35
07-17-2019 17:35
My Sister has the HR2 and she just messaged me that she cannot SYNC to the same workweek hustle that i am in ....what is going on???
07-17-2019 18:11
07-17-2019 18:11
Nope. This is a Fitbit issue. I updated and started having this issue. Please fix this on your end.
07-17-2019 18:19
07-17-2019 18:19
I am also having the same issue - in a challenge with my mom
Best Answer07-17-2019 18:28
07-17-2019 18:28
This is not working any other fixes
Best Answer07-17-2019 18:31
07-17-2019 18:31
I am having the same issue! I "updated" my Fitbit today and now it wont sync to the challenge.
Best Answer07-17-2019 23:24
07-17-2019 23:24
I’ve got exactly the same problem and no fix seems to work 😞
Best Answer07-18-2019 03:17
07-18-2019 03:17
Looks like there is major lag time for the updates to the challenges, I finally updated in the early am , this is a Fitbit issue for sure
02-09-2020 16:13
02-09-2020 16:13
05-06-2020 16:50
05-06-2020 16:50
My charge 3 also isn't syncing with my 'Workweek Hustle' challenge 😞 It's logged the steps, but not with the challenge, just today this has happened for some reason 🤷:male_sign:
Have tried:
refreshing
Bluetooth on/off
uninstall and reinstall app
log out / in
reboot tracker
notifications turn on/on
phone on/off
laptop on/off
login on a different device (ipad)
I didn't manually update any steps - all are from my tracker.
ANY ideas would be greatly appreciated, Fitbit!
Very frustrating, because at this moment, it's 17k steps behind.
07-04-2020 03:07
07-04-2020 03:07
Has anyone been successfully at fixing this issue? Super Frustrating.
Have tried:
refreshing
Bluetooth on/off
log out / in
reboot tracker
phone on/off
laptop on/off
Very frustrating,
07-07-2020 21:11
07-07-2020 21:11
My Charge 3 just started doing this within the last week after an update. I’ve also tried all of the tips and tricks suggested with no resolve.
07-07-2020 23:02
07-07-2020 23:02
I hope they figure this out sooner rather than later. Super frustrating. Glad to know I'm not the only one.
12-20-2020 09:02
12-20-2020 09:02
Tried all the above nothing as solved the issue
