01-24-2020
05:11
17:35
01-24-2020
05:11
17:35
How do I fix time on clock
01-24-2020 06:11
01-24-2020 06:11
To fix your time on the clock face on the screen, go to advanced settings through your profile menu. There will be a time zone option, and change that to your time zone.
Best Answer01-24-2020 13:33 - edited 06-11-2024 06:11
Hi there @MauraKB, welcome to the Community Forums. We'll be glad to help.
I'd recommend following @SkullBurner's directions. Keep in mind that your Charge 3 may be showing an incorrect time if it hasn't synced or if it has been unpaired from your account. Note that your Fitbit grabs the time of the device you're syncing with so it can update the time throughout the day.
Besides the restart you've performed, I'd suggest to take a look at: Why won't my Fitbit device sync?
If the time keeps showing incorrect after syncing your Charge 3, I recommend changing your timezone to a complete different one, sync your device, put the correct time and sync again. To change the time make sure you are following the instructions provided in the help article How do I change the time on my Fitbit device?
