11-01-2020
10:33
13:03
11-01-2020
10:33
13:03
Does Fitbit plan on improving the Charge 3 brightness?
I just loaded the recent update hoping the brightness would change. It did not. Will it ever improve?
11-01-2020 10:41
11-01-2020 10:41
My charge 3 is too dim as well! I tried the long reboot and it didn’t work either. 😏
11-04-2020
11:29
08:33
11-04-2020
11:29
08:33
@Tomert @Kootenay It's good that the community is growing!
Let me help you with your Charge 3 screen being too dim and thank you for troubleshooting this issue. I just want to verify that your tracker's aren't either in the Do not Disturb mode or Sleep mode as these modes will dim your tracker's screen.
I look forward to your reply.
Best Answer11-06-2020 19:20
11-06-2020 19:20
Mine is in the normal mode.
Best Answer11-06-2020 21:20
11-06-2020 21:20
My Charge 3 is in the normal mode but too dim to see.
11-06-2020 22:53
11-06-2020 22:53
HI, how do we know what 'mode' the tracker is in? Maybe I have accidently put it to sleep or do not disturb, although I can still see it, albeit very faint.
Best Answer11-07-2020 02:38
11-07-2020 02:38
I just found the solution this morning. Swipe right to left 4 times. Click on settings. The first option is brightness. You can change from Dim to normal or to auto. It's worked for me so I hope this works for you too.
