02-18-2019
11:41
11:25
02-18-2019
11:41
11:25
My Charge 3 seems to be syncing based on the keep-alive widget, but when I open the app, it has not updated. I've tried several fixes and suggestions already, but the same problem just keeps happening. I can't bluetooth forget or uninstall/reinstall the app every day or two. And the Charge 3 says not tracking sleep even though it does show in app WHEN I can get it synced.
02-19-2019 05:34
02-19-2019 05:34
Welcome on board @Dkociuruba, it's nice to see you around here! Thanks for already troubleshooting this inconvenience. Nice way to go!
While reading your post I was wondering if you've checked that the mobile device you're syncing with is included in our list of supported devices? If you're not sure, please see: Which phone and tablets can I use with my Fitbit watch or tracker?
Please keep in mind that when a device is not supported we cannot guarantee its functionality with the Fitbit app. It might work at a certain time and then it can stop working out of nowhere after an update. This is because the app is not optimized to that device and any change could impact the performance.
If your mobile device is included, please see: Why won't my Fitbit device sync?
You can add several Fitbit widgets to your Android phone, including the activity goal widget and widgets that allow you to quickly log activity, food, sleep, and more. The activity goal widget allows you to view your progress toward completing your daily activity goal directly from your home screen without opening the Fitbit app. For more information about changing your primary goal, see How do I change the activity goal on my Fitbit device?
Depending on your phone, you can add Fitbit widgets in one of two ways:
Or:
Hope this helps, let me know if you need further assistance!
Best Answer04-28-2019 09:38
04-28-2019 09:38
I have the Samsung s8 and can't find widgets anywhere. Any advice? Looking for keep alive, can't see in Google Play...
Best Answer04-29-2019 08:51
04-29-2019 08:51
Hello there @Bolicsteroids, thanks for jumping in here! Have you tried the steps I've posted here to add a Fitbit Widget to your Android phone? Are you getting anything different when going to either of the 2 options mentioned in the post?
In addition, if you want to see real-time data I'd recommend taking a look at: Can I see real-time data in the Fitbit app?
Give this a go and let me know the outcome.
Best Answer04-29-2019 09:31
04-29-2019 09:31
In option one, the only contents in Apps are Exercise, Alarms, Weather, Settings, Relax and Timers.
The other option, assuming by 'home' you mean my phone 's home button, it's just brings up Google assistant.
Best Answer04-29-2019 11:11
04-29-2019 11:11
Hi there @Bolicsteroids, thanks for coming back and for the details provided.
Would you mind sending me a screenshot of what you're getting when attempting the steps provided? My phone worked with the second option just fine.
As mentioned above, it will depend entirely of your phone model, but this should be available in your widget drawer by long pressing the main screen of your phone. This article will provide you more details: About the Fitbit app.
Best Answer04-29-2019 11:15
04-29-2019 11:15
Best Answer04-29-2019 11:22
04-29-2019 11:22
I've no idea how to attach the screenshots!
Best Answer04-29-2019 11:36
04-29-2019 11:36
Hi @Bolicsteroids! In order to add a photo to your reply, please:
* When you're in the reply page, click on the Photos icon.
* Then, click on the Choose File in the middle of the grey window that will pop up
* Search for the photo on your computer and click on Open.
* Once the image shows up in the grey windows, select the size and the position (1) and click on Done (2)
I hope this can be helpful; give it a try, I'll be waiting for your reply! ![]()
Best Answer06-18-2020 03:25
06-18-2020 03:25
I think my Samsung S7 isn't supported anymore, I've tried moving the fitbit widget it won't move. No sync, no time updates, it says I need a keep alive widget, however it's nowhere to be found, so I'm buying a proper watch, had enough now. No more fitbit for me
