11-06-2020
03:47
18:29
RicardoFitbit
11-06-2020
03:47
18:29
RicardoFitbit
I have done all that has been suggested on the forum and the black lines still remain. Whichever clock face I choose it makes no difference. My charge 3 is only just over 12 months old. I am now on my 4th Fitbit device and have had problems with all of them before they have been out of warranty. Loosing faith in them now and think it's time to try an alternative.
Hi @Suedewison, welcome to the Community Forums!
Thanks for bringing this to our attention and for trying some troubleshooting steps before posting over here, I understand how frustrating this situation can be for you. If you haven't already done so, I recommend you to restart your Charge 3 following the next steps and let me know if the issue with its display persists:
I'll be here if further assistance is needed.
Best Answer11-07-2020 03:44 - last edited on 11-08-2020 17:41 by LiliyaFitbit
Good Morning
Thank you for your email and assistance. I have done as you requested and the lines still appear across the screen.
Regards
Best AnswerI have lines on mine as well.. I tried doing the same thing several times..
Best AnswerI have the same issue my fitbit 3 is only 10 months old, tried your suggesting also tried uninstalling and reinstalling the app also changing the clock face but nothing has helped.
Best AnswerDear Moderator,
I've the same problem.
And your suggest doesn't help.
Regards,
Jan
