01-12-2020 08:30 - last edited on 09-24-2020 19:06 by
Hi
i have tried restarting my Fitbit but this hasn’t sorted the problem.
Please can can advise what I should do
01-13-2020 13:10
01-12-2020 09:37
01-12-2020 09:37
Try a Long Restart:
CHARGE 3 LONG RESTART
Connect the device to the charging cable.
While the device is plugged into the charging cable, press and hold the button down for 15 seconds.
The device turns on and shows a battery icon. Two vibrations occur: first a short vibration, then a medium vibration.
The device turns off.
The device turns on and shows a progress bar and short vibrations occur. The progress bar completes. Note: A total of 7 short vibrations occur.
Remove the device from the charging cable. The device shuts down.
Important: Plug the device into the charging cable again.
Best Answer01-13-2020 08:56
01-13-2020 08:56
Best Answer01-13-2020 09:12
01-13-2020 09:12
I am having similar problems. At first, the solution posted worked (some month ago). Then, I experienced unusual display phenomenon, including fractured lines and incomplete display.
At this point, all but the display seem to be working. My Charge 3 is, in fact, recording my information. I simply cannot see ANYTHING on the display irrespective of what I do.
This is my second Charge with problems. I am beginning to be very unimpressed. Any help?
Best Answer01-13-2020 13:10
01-13-2020 13:10
Contact Customer Support.
Best Answer01-13-2020 13:33
01-13-2020 13:33
Hi there @Oreostorm and @mnpugh1, thanks for the details provided and for your efforts in troubleshooting your Charge 3 trackers.
Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Thanks for your help @SunsetRunner.
Let me know if there's anything else I may do to help you.
