01-13-2020 00:21 - last edited on 09-24-2020 19:06 by
Charge 3 screen has broken graphics on left side of the screen. It started today. I have restarted multiple times with no success. I cannot read messages that come through because of this.
01-14-2020 04:21 - edited 05-23-2025 06:21
Hi there @piemd229, welcome to the Community Forums. Thanks for the details provided about your Charge 3's screen and for taking the time to restart it prior to posting here.
Since the restart didn't work, I'd recommend to perform a long restart by following the steps below:
In case that neither of the restarts work, please check in your Fitbit app if your Charge 3 is still syncing. If so,change the clock face to a different one to see if this brings back the display. Don't worry if you cannot see anything on the display by now, this process is done through the Fitbit app.
Give this a go and let me know the outcome.
Best Answer01-14-2020 06:12
01-14-2020 06:12
The same thing has happened to my Charge 3. I've tried to reset my fitbit and change the clock face but I still have lines on my screen.
Best Answer01-14-2020 06:21
01-14-2020 06:21
I have exactly the same problem, distorted screen appeared yesterday, and now today the screen will not come on at all. But it has synced. I tried changing the clock face via the app, and the app said this had been successful, but still have a blank screen. I've tried restarting the device as described, but didn't work. Very frustrating, and annoying!
Best Answer01-14-2020 08:34
01-14-2020 08:34
I have had the same problem two times before. I have tried the reset with no success. I was told by Fitbit that my device was “corrupted “ and was given a new one. First two were covered by warranty(first one was charge 2, second charge 3). My “new” charge 3 now has done the same thing. Chances are warranty won’t cover this one. Makes me wonder why I bother with Fitbit. I have had multiple friend have the same experience and have not repurchased Fitbit and have gotten different brands.
Best Answer01-16-2020 17:59
01-16-2020 17:59
Hello.. thank you for the suggestions. I tried the troubleshooting that you listed but with no success. The messages that come through are still not legible. The lines are still there.
Best Answer01-16-2020 18:36
01-16-2020 18:36
I have done this too but it isn’t shutting down like it’s supposed to the bar goes only 2-4 vibrations and then pops back to the smiley face screen with the lines all across it. I’ve tried 8 times and it just won’t shut off to restart. I even made my husband try and he couldn’t get it to work either.
