07-27-2021
15:56
04:17
WilsonFitbit
07-27-2021
15:56
04:17
WilsonFitbit
Why does the charge 3 constantly get require lost Bluetooth repairing messages.
07-28-2021
04:22
10:19
07-28-2021
04:22
10:19
Hello @TimothyS. Welcome to the community forums!
Thank you for the detailed information. At this time, I'm not sure about what could be causing this inconvenience, but if you have any other Bluetooth devices paired to your phone, I'd recommend removing them and then please restart your phone and test the behavior of your Charge 3.
In addition, I'd recommend restarting your Charge 3 by following the instructions here. Once your tracker is restarted, please remove the Bluetooth connection between your phone and your Fitbit device:
*On your phone, tap Settings > Bluetooth > the information icon next to the name of your Fitbit device > Forget This Device.
*Open the Fitbit app and set up the connection again. You should receive a message asking you to allow your Fitbit device to pair with your phone. Tap Pair to approve the request. Also, please make sure no other mobile devices are nearby as this can interfere with the set up or sync process.
If you encounter any inconvenience to set up your Charge 3, please check: Why can't I set up my Fitbit device?
Hope this helps.
Best AnswerHi
I have the same problem. My Charge 3 loses Bluetooth connection constantly now over 3-4 weeks. Some days i have to pair/set up my Charge 3 to my phone 2-3 times in a day. Needless to say, it is very, very annoying. I have restarted Charge 3 over 10 times and i don't know what else can i do.
04:14
10:31
07-30-2021
04:14
10:31
Hello @roosamanna. Nice to see you around.
I'm sorry for the experience and thank you for providing information about the issue and for your help in trying to resolve this matter. While you've tried to restart your Charge 3, I'd recommend performing a long restart by following the instructions below:
Also, if you have too many devices connected to your phone's Bluetooth, I recommend removing some of them and restart your mobile device. Also, make sure that your mobile device meets the requirements listed here.
Hope this helps.
Best AnswerHey
Thank you, i’ll try that and hope this fixes the issue.
@roosamanna Thank you for your reply.
I hope those instructions help to resolve the inconvenience.
See you around.
