06-24-2021
08:40
08:52
WilsonFitbit
06-24-2021
08:40
08:52
WilsonFitbit
My Charge 3 and iPhone are in sync but the actual step count only shows on the Fitbit app but it is not displayed on the Fitbit device. How can I correct this?
Moderator edit: subject for clarity/format
@NanaP62 Thank you very much for your reply and for the picture.
I also appreciate the additional details and thanks for following our suggested tips. I'd suggest trying to change the clock face on your Charge 3 for one that displays your steps. For more information about clock faces, I recommend visiting the following thread.
For instructions about how to change the clock face, please follow the steps here: How do I change the clock face on my Fitbit device?
On the other hand, take into consideration that you can review your steps taken by swiping up from the clock face on your tracker. If you have any questions about how to navigate your device, please click here.
Hope this helps.
Hello @NanaP62. Welcome to the community forums!
Thank you for the detailed information. If you have tried to restart your Charge 3 and the inconvenience persists, please try to perform a long restart. A long restart is different than the basic one and you can complete the process by following the instructions below:
Hope this helps.
Best AnswerHello, thank you for the information, however after conducting the long restart as instructed above, the display on the fit bit is still the same. It shows the little footprints with the circle and the time, but it does not show the actual number of steps. The steps are reflected in the app on my phone. Do I need to do something differently to set up the display on my watch? Below is a picture of my display. sorry it came through a bit blurry.
Hope this helps.
Perfect, that is exactly what I needed. As a side note, I did try the swiping up from the clock face on my tracker and it wouldn't populate there either. But I'm all set now. thank you!!!
