09-08-2021
06:36
07:09
WilsonFitbit
09-08-2021
06:36
07:09
WilsonFitbit
I travelled into another time zone at the weekend - Charge 3 correctly changed to one hour behind my home time zone. Travelled back home and it is now showing correct time zone but wrong number of hours behind GMT. In Atlantic time zone, shows as -3 hours GMT. Should be -4 hours.
Tried cheating the system by setting it to Toronto time zone, which is showing as -4 hours GMT - that didn't work, it still stays as wrong time, even though synced.
09-12-2021 19:15
09-12-2021 19:15
Thank you for the update, @Frankie66.
Please try the following:
Whether your Charge 3 is still showing the wrong hours difference, please set it up as a replacement device:
If you have any question, please let us know.
07:11
05:26
09-08-2021
07:11
05:26
Hello @Frankie66. Welcome to the community forums.
Thank you very much for the detailed information and for the troubleshooting steps you've tried prior to posting. If the time on your Charge 3 is still incorrect after syncing, I'd recommend making sure the time zone setting in the Fitbit app is correct. For more information, I recommend visiting the following help article: How do I change the time on my Fitbit device?
09-08-2021 07:13
09-08-2021 07:13
The time zone itself is correct. It is showing the wrong hours difference from GMT. Shows -3 should be -4. Is it possible to change that?
Best Answer09-12-2021 19:15
09-12-2021 19:15
Best Answer09-15-2021 04:43
09-15-2021 04:43
Hm. For some reason, although I had taken that first step several times and it hadn't worked, I did it today and it is now showing the correct time. Weird but problem solved. Thank you for your help. 🙂
09-15-2021 14:27
09-15-2021 14:27
Thanks for your response, @Frankie66.
I'm glad to hear that you resolved the issue with your Tracker. Thank you for letting us know.
On another note, you are welcome to visit the Health & Wellness board to talk with other members about health and fitness.
Feel free to contact us at any time.
