10-08-2018
13:38
15:47
10-08-2018
13:38
15:47
My charge 3 was synced fine with my Samsung s7 but suddenly won't sync. I tried unpairing and re pairing but it wont pair now. I tried with my old iPhone and it won't pair with that either. Any ideas?
10-08-2018 13:48
10-08-2018 13:48
Is it still connected to the bluetooth on your phone? Mine was fine yesterday but this morning wouldn't sync and had lost the Bluetooth connection. A restart of the 3 fixed it.
10-08-2018 14:44
10-08-2018 14:44
@AnnaFin76 @vee Have you two tried the restart steps outlined in this pinned thread? If not, I suggest giving those steps a try and let me know your results once you've tried that.
10-08-2018 15:38
10-08-2018 15:38
I bought one last night and set up and synced fine. This morning could not sync after restarts of everything and even unpaired and repaired. I thought it was the device so exchanged it. I haven't had the replacement for one full day and is now having same sync issues. I called customer service and all they do is ask if you went reset everything. Very dissappointed, I had high hopes for this! I loved the old charge hr and never had any sync issues. Fitbit needs to look I to this asap!
10-09-2018 03:09 - edited 10-09-2018 03:14
I think it's more than this. I got my charge 3 yesterday and it wasn't syncing. I followed the instructions and it started syncing and it was syncing this morning. However, now it has stopped again. I never had an issue like this with my charge 2. I've just rebooted the charge 3 again and it is now syncing again - but of course you don't want to be doing this every day!
10-09-2018 11:54
10-09-2018 11:54
I am having the same issues with my new Charge 3. It was find when I first set it up but for some unknown reason it just stopped synching. Also never had this problem with my Charge 2. I've done all of the trouble shooting short of rebooting the Charge 3 (I don't have the charger with me at work) and nothing worked. UGH
10-09-2018 12:59
10-09-2018 12:59
I'm having the same issue, the Fitbit will just stop syncing until rebooted (And I don't have the cable with me).
Should I return it? seems to be a defect for several units.
10-09-2018 14:25
10-09-2018 14:25
10-09-2018 14:27
10-09-2018 14:27
10-10-2018 05:46
10-10-2018 05:46
I had to reboot mine completely again yesterday and then it uploaded inconsistent step amounts. Am giving it one last go but if this carries on it's going back. So disappointing as I love it other than the syncing issue
10-10-2018 06:19
10-10-2018 06:19
I rebooted mine last night and it worked but woke up to same issue. The app and watch do not sync. I am so frustrated- ran out to buy the Charge 3 but there is clearly a major glitch. I had my Charge 2 for years without any problem like this.
10-10-2018 08:34
10-10-2018 08:34
10-10-2018 08:35
10-10-2018 08:35
10-10-2018 19:23
10-10-2018 19:23
Same issue here. Purchased yesterday and it was working fine but now will not connect to bluetooth despite multiple restarts.
10-20-2018 20:14
10-20-2018 20:14
Same issue, have done reset, tried to unpair/repair. Now I can't pair with my phone and it won't let me set up the tracker again in the app.
Immensely frustrating. What is the deal, fitbit?
10-29-2018 11:10
10-29-2018 11:10
I am having the same problem. l have an S7 too. My Charge 3 synced fine for a couple of days and will not sync now. I've reset it 2 or 3 times, I've gone through all the steps on the advice given, including re-installing the app, but nothing works. Just now I tried putting the cable into my computer to see if I could sync through that (Apple Mac) but can't see a way to do that either... Help, please, because it's useless if it won't sync.
10-29-2018 11:13
10-29-2018 11:13
Me too. Samsung S7. Worked well for a couple of weeks. Now no good. No pairing. Please confirm a firmware fix is coming or I will return.
10-29-2018 11:24
10-29-2018 11:24
Mine will sync with my S8 at random times, but not when I schedule a sync. I've found restarting my phone will often sync it, but it is frustrating. I just restarted my phone, the statistics all match what is on my Charge 3, but it still says it synced 4 hours ago. Frustrating.
10-29-2018 11:40
10-29-2018 11:40
I'd tried restarting phone, reinstalling app, turning bluetooth on and off, resetting the Fitbit itself - none worked. Have just tried removing the Charge 3 from the app (using the delete icon) and then setting it up as a new device again - and that has worked (the step and exercise data have synced, though the sleep data from last night isn't there). I'll see how it goes... fingers crossed that this doesn't keep happening. I did notice that there'd been an Android software update very recently so I wonder if that has caused the glitch. If that's the case, and setting the device up again sorts it for the long term, I'm happy with the Charge 3. If not, I'll have to go back to the Charge 2HR.
10-29-2018 11:54
10-29-2018 11:54
