11-11-2018
10:20
15:03
11-11-2018
10:20
15:03
I upgraded from my Charge 2 to a Charge 3 and am used to being able to turn my wrist from a downward position and move towards my face and see the time and display turn on. My Charge 3 does not work that way. Any motion I make with my wrist does not activate the display? Is my unit defective? Or is this the standard behavior now? Or is there a setting I can activate to make it work again. I'm quite frustrated since I depend on the unit to work when I turn my wrist. If I cannot get it to work I'll have to downgrade back to the Charge 3.
Thank you.
11-11-2018 10:25
11-11-2018 10:25
Hold the side button for a second, turn on screen wake. Rotating your wrist 90 degrees will wake the screen up.
11-11-2018 10:25
11-11-2018 10:25
11-11-2018 20:53
11-11-2018 20:53
I found this can be turned on or off in "settings" on the Charge 3. I have found that when the battery is low screen wake and notifications automatically are turned off, however, you can override this manually.
11-12-2018
03:26
07:58
11-12-2018
03:26
07:58
A warm welcome to the Community @vonman001, @SarahRhea and @Jinikay thanks for stopping by.
I agree with our friends here, have you checked if the quick view option is on? If you haven't, you can follow their recommendations or you can check the help article How do I see the time on my Fitbit device?.
Let me know how it goes. ![]()
Best Answer11-12-2018 06:41
11-12-2018 06:41
Thank you to all. Solution was easy and now its working exactly as i like it to.
11-14-2018
03:08
07:58
11-14-2018
03:08
07:58
Thanks for the update @vonman001. I am glad to hear that your tracker is working properly. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up! ![]()
Best Answer12-28-2018 06:03
12-28-2018 06:03
Wrist rotation does not work on charge 3
Best Answer03-30-2020 06:46
03-30-2020 06:46
Thank you! This was a very simple answer to a problem that has bothered me since I first setup & realized that I missed that option. 🤗
Best Answer10-08-2020 22:38
10-08-2020 22:38
Thanks so much! Yay, the quick view works now!!
10-09-2020
08:23
08:04
10-09-2020
08:23
08:04
Welcome to the Community, @Fish42.
It's great to see here that the instructions provided in this thread worked. If there is anything else we can help you with, do not hesitate to post it.
Happy stepping!
Best Answer07-25-2022 07:19
07-25-2022 07:19
This tends to happen to me when my battery gets to about 30%. Thankfully I know how to fix it now 😉
