12-15-2017
03:08
18:54
12-15-2017
03:08
18:54
My Fitbit Charge 2 seems to be working fine but not syncing with my iphone since yesterday . Display on the app shows continuous looking ? Any ideas please?
12-15-2017 03:33
12-15-2017 03:33
Welcome to the Fitbit Community @marionrodgers, hope you're doing great!
Keep in mind that syncing difficulty is usually caused by a missing requirement. Verify each requirement before moving on to the troubleshooting steps.
If your device still won't sync, try these steps:
Give this a shot and let me know how it goes!
12-15-2017 03:33
12-15-2017 03:33
12-15-2017 04:01
12-15-2017 04:01
Thank you My iphone just had a system update and when I returned my Bluetooth finally recognised my Fitbit and all is now syncing correctly. Merry Christmas
Best Answer12-15-2017 04:12 - edited 12-15-2017 04:13
Awesome! Hope to see you participating in the Community more often since I think it would be awesome for you to explore our Community. You can go ahead and log to any of the topics that might be of your interest in our Discussion boards. Feel free to comment and contribute with your knowledge and experience.
Merry Christmas 2 you 2! ![]()
Best Answer12-19-2017 07:02
12-19-2017 07:02
I have tried everything on the list besides restart the my Fitbit because I’m at work now. I have restarted my phone multiple times, deleted and redone loaded the Fitbit app, and deleted the charge 2 from my account but my phone still won’t recognize my charge 2 (which needs an update) but it cant find it. I’m not sure what else to do. My iPhone or app won’t locate the charge 2 and nothing has changed with any of my devices.
Best Answer02-01-2018 13:25
02-01-2018 13:25
My Fitbit stopped syncing a few days ago when I did the latest update. iPhone has most current update. Turned on and off iPhone, uninstalled and installed Fitbit app. Bluetooth (turned on and off) is looking for it and nothing.
Best Answer08-04-2018 17:44
08-04-2018 17:44
It worked! Thank you so much!
Best Answer10-27-2018 12:12
10-27-2018 12:12
Hello,
I've just switched from an Android phone to an Iphone just yesterday, and I cannot get the iphone to "find" my fitbit at all. I've tried uninstalling and re-installing the app multiple times, restarting the tracker while its plugged into the wall, switching on and off the bluetooth on the iphone, as well as restarting the iphone.
Whenever I go through the fitbit app and try to set up my Charge 2, I just get a continuous "searching" status bar at the bottom of the screen in the app.
Is there anything else I can try, because I can't seem to get the iphone to "find" my charge 2.
Thanks, Eric.
Best Answer02-03-2020 08:45
02-03-2020 08:45
Still not working for me. I have trouble getting Charge2 to actually restart.
Best Answer05-13-2020 15:21
05-13-2020 15:21
I’ve tried all the fixes above and my iPhone’s Bluetooth still does not “see” my FitBit charge 2. iPhone’s system is latest update, as is firmware / software of Charge 2.
ummmm
Best Answer05-13-2020 20:36
05-13-2020 20:36
I tried all of the steps suggested and nothing worked BUT....
then I tried to unconnected and reconnect the Bluetooth connection and that worked.
Disconnect:
1. Go to Settings > Bluetooth > find your Fitbit on the list of devices > i / info > forget this device.
2. Your device should then show up on the list of “other devices“ at the bottom of the page.
3. Reconnect your Fitbit device
4. Force sync your device by:
A. Drag down on the main Fitbit app dashboard
B. Goto your account page. Dashboard > click on your picture (upper left) > your device > scroll down to “sync now”
good luck!!!
05-14-2020 01:55
05-14-2020 01:55
Recent apple update and lost connectivity with my Fitbit. Tried this and now syncing days worth of data. Thanks
Best Answer05-14-2020 03:37
05-14-2020 03:37
Happy to say I have followed your instructions and as my Charge 2 was not syncing to my iPad and it has worked. Thank you
Best Answer05-15-2020 00:42
05-15-2020 00:42
I have exactly the same problem.
It won't work whatever I tried.
Must have something to do with the last update of my Apple Phone.
Best Answer05-15-2020 00:43
05-15-2020 00:43
I have exactly same problem.
I have tried everything now but does not work.
Best Answer05-15-2020 06:27
05-15-2020 06:27
I tried all the steps you suggested and my Charge2 still is not syncing with either my iPad or iPhone. I think it is due to updates on iOS as iPad synced prior to update yesterday while iPhone did not as it had its update earlier.
Best Answer05-15-2020 14:56
05-15-2020 14:56
This fix, almost tantamount to “unplug device and start all over,” should not be necessary at all if FitBit was doing THEIR homework: they know when Apple is going to do an iOS upgrade, and have betas in their labs so they can do these fixes “in the factory” so we don’t have to tear our hair out reinventing the wheel.
05-16-2020 00:32
05-16-2020 00:32
had to do this, before it just kept trying to connect, remove, re-add, connected first time, same everytime there is an update.....
Best Answer05-16-2020 03:27
05-16-2020 03:27
Wish I’d found Ashepard’s advice last night... THIS should be part of the Fitbit “sort it out” steps... spent hours last night force quitting and restarting my Fitbit - nothing. One flick if the Bluetooth “forget this device” this morning and all immediately sorted.
thanks Ashepard!
Best Answer05-22-2020 13:15
05-22-2020 13:15
This was a very good tip. No my Fitbit is syncing. Thank you.
