11-19-2020
01:18
06:21
AlejandraFitbit
11-19-2020
01:18
06:21
AlejandraFitbit
My Charge 3 is intermittently adding tens of thousands of steps to my step count. It doesn’t happen every day, and apart from that the step count seems to be calibrated fine. However yesterday my step count suddenly jumped by 30000, and a week or so previously it jumped by 10000.
Anyone else notice this issue or have a fix?
thanks
11-23-2020 06:21
11-23-2020 06:21
Welcome to the Community, @Kubla.
For tips about improving accuracy, I recommend checking the help article: How accurate are Fitbit devices?.
Several things can affect the number of steps your Fitbit device records, including where you place the device, if you wear it on your dominant or non-dominant hand, and your stride length. If you're pushing a stroller or shopping cart, try putting your device in your pocket or use GPS to record your activity, if possible.
If it still seems like your device is undercounting or overcounting steps, try a step test. While you perform your step test, make sure you:
-Walk at a normal pace
-Don’t hold anything in your hands
-Put your arms down at your sides, swinging naturally
-Count 1 step for each foot
-To avoid getting an additional step when you bring your feet together, after you reach 100 steps:
Here’s the step test:
Let me know the outcome.
Best Answer01-21-2021 12:22
01-21-2021 12:22
This started happening to me too over the past 12 months it has probably happened 6 or 7 times. No one can suggest a fix.
it's very frustrating. it happened today. I had done around 7000 steps and then my Fitbit started vibrating....telling me I had been awarded a 60000 step badge.....and my tracker says I have walked 63,856 steps which is absolute nonsense.
I'm getting really cheesed off with the whole thing, I want to earn a badge because I've worked for it not due to some error.
also my calorie burn for the day reads 6174 which is hugely inaccurate and can only be attributed to the randomly added step count.
I have used a Fitbit device for many years to track diet and rely on keeping calorie intake "in the zone", so this kind of error really makes.having a fitbit a complete waste of time and money.
