11-08-2020
20:04
12:57
11-08-2020
20:04
12:57
My Charge 3 screen stopped working about a week ago. I was going to let it die and try to charge it to see if that would bring it up but it didn’t work. I came on here and tried to ‘reset it’ with the plug it in, hold the side button, unplug then replug but that didn’t help either. Not sure what to do? It was purchased 12/2019, so it’s just under a year old.
11-08-2020 23:04
11-08-2020 23:04
Same problem..and it is also not synced to my phone anymore
Best Answer11-09-2020 01:21
11-09-2020 01:21
Hi
I have the same problem with mine. Bought mine Jan 2019 but since saturday the screen just bounces around , tried the restart that worked for a short while. Placed it n charge last night and this morning my screen is black , no response on my fitbit , wont even come on.
Best Answer11-09-2020 17:12 - edited 11-09-2020 17:14
Welcome to the Fitbit Community, @Btribou @PetraRoux @SAN001a.
@Btribou I am sorry to hear your Charge 3 screen stopped working. Thanks for trying to resolve this, I appreciate the additional details and I am here to help. I recommend trying the following:
@PetraRoux @SAN001a I am sorry to hear you're experiencing the same issue with your devices. Thank you for your efforts and the additional details. Upon checking with our Support team, I was told that you have already contacted them and that they were able to assist you. Thank you for your time and efforts.
Let me know how it goes.
Best Answer11-10-2020 12:28
11-10-2020 12:28
I have tried this several times and it doesn’t work. Can you tell me what the next steps would be?
11-10-2020 12:37
11-10-2020 12:37
I received a replacement less than 3 weeks ago for the same challenge..today my NEW fitbit is having this issue. Ive tried all of the suggested trouble shooting a number of times. 😡. Seriously.. 2 Fitbits with the same issues in less than 3 months???? Guess I'll have to call the customer service once again.
11-10-2020 13:05
11-10-2020 13:05
Hi I've had the same problems the fitbit is not syncing with my phone I've just done the 15 sec thing and it comes up with a smily face . It was working fine till the update which I did a couple of nights ago . I bought this fitbit in January 2020.
11-10-2020 13:26
11-10-2020 13:26
Same problem and this doesn’t work at all! What do we all do now with a Fitbit that doesn’t work due to your update?
11-11-2020 00:11
11-11-2020 00:11
Best Answer11-11-2020 02:30
11-11-2020 02:30
I’ve had exactly the same issue.
I have been offered a replacement or 50% off a new product. The email comes with 2 links. One to replace and the other to upgrade. What they don’t tell you until you’ve clicked is that the 50% is on a selected range of trackers only.
I went back to the original email but the like-for-like link has now gone 😡 Not sure I want another Charge 3 as the screen fade seems to be a common problem.
Best Answer11-11-2020 03:27
11-11-2020 03:27
That’s where I am at too! I don’t think I want another charge 3 after all of the replies to my thread. This seems to be a common problem and I don’t want to get a replacement and then have that not work either. I was looking at the charge 4, is that one of the 50% offs? What a headache, because I really love my charge 3 prior to this.
Best Answer11-11-2020 09:47 - edited 11-11-2020 18:52
Tech support unable to correct challenge, item being returned for a replacement.
Best Answer11-11-2020 10:55
11-11-2020 10:55
This should be put on social media unless there is satisfaction on this issue.
Best Answer11-11-2020 10:57
11-11-2020 10:57
I would like someone who can refund or give me another Watch. Money is too tight to have this happen, and not only to me but several others.
Best Answer11-11-2020 11:12
11-11-2020 11:12
The same problem I've tried everything to get the screen back to no avail, it's working ok through the app but what's the point of that , so aren't these watches supposed to last more than a year then ?
quite expensive if that's the case
