04-04-2021
12:46
04:15
WilsonFitbit
04-04-2021
12:46
04:15
WilsonFitbit
I can't see the screen in daylight, it's like it doesn't light up even in the shade. It only works inside. Any advice to fix it please?
04-05-2021 03:16
04-05-2021 03:16
I’m having the same issue - very annoying. Fitbit about 3 years old I think...
Best Answer04-05-2021 04:15 - edited 04-05-2021 04:16
Hello @FreshTherapies It's great to see you around. @germcq Welcome to the community forums.
I'm very sorry for the experience. Please make sure that the Charge 3 is not set to Sleep Mode. Take into consideration that when Sleep Mode is activated, the screen's brightness is set to dim.
If this is the case, please disable the Sleep mode. You can do this on the quick settings on your Charge 3 screen. Also, make sure to set the correct Brightness Setting, this can be found in the Setting App on your Charge 3. For more information about how to navigate your Fitbit device, please click here.
Lastly, perform a restart by following the steps in this help article: How do I restart my Fitbit device?
Hope this helps.
Best Answer11-10-2022 09:43
11-10-2022 09:43
thanks for all the info, but I have tried all of these to no avail. 🙄
what would be the next step?
Best Answer11-10-2022 09:53
11-10-2022 09:53
@FreshTherapies all you can do is try customer support.
when there is someone available, chat is an option. Phone or Twitter works well, too.
https://myhelp.fitbit.com/s/support?language=en_US
Support is limited by the number of representatives available at a given time and the hours of operation. Chat lines are open when they have live help.
USA: call (877) 623-4997
UK: call 0800 069 8505
INDIA: call 000 800 050 1057
IRELAND: call 01 691 7502 (country prefix: +353)
Other contact options:
USA: click
Canada: click for options
