08-14-2022 00:12
08-14-2022 00:12
I've rebooted. I've followed your instructions on this forum but the screen is still blank. Battery is fully charged. When I put it on charge to reset the screen it shows a battery icon with ! In the middle of it.
08-16-2022 08:53
08-16-2022 08:53
Welcome to the Fitbit Community, @neill065. Thank you for mentioning the steps that you have followed in order to removed the black screen on your Charge 2.
Please check instructions of help article: Why isn't my Fitbit device's battery charging?
Keep on visiting the forums.
Best Answer08-16-2022 13:05
08-16-2022 13:05
Hi Andrea I've done as you've requested and even rebooted, restarted and added the tracker as new again. It was OK for 5 mins and now it's back to having no charge with black screen again. What's the next stage?
Nicola
08-16-2022 15:14
08-16-2022 15:14
Same with my charge 2. Happened just this morning after my run/walk. Went 2.35 miles then screen went blank/black. Cleaned, can’t restart, still blank….would like timely help to fix pls.
thanks
Best Answer08-17-2022 06:31
08-17-2022 06:31
Thanks for getting back to us and for following advised troubleshooting steps @neill065. Welcome @JobaRules. Thank you for mentioning the steps you have followed.
I understand how frustrating this could be and the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Best Answer08-17-2022 10:51
08-17-2022 10:51
I've just had a live chat and went through the problems I'm having and it seems nothing you can do. Offered to send over warranty details but told them not to bother as the fitbit is over 3years so nothing they can do. In the meantime I've now bought a Charge 4. So we'll see how long this one lasts. Thank you, Nicola
08-18-2022 06:49
08-18-2022 06:49
Thanks for getting back to us and for letting us know about your experience @neill065.
I´m glad to hear that you´ll get back on track with a Charge 4.
Best Answer11-09-2022 23:46
11-09-2022 23:46
To restart your tracker please do the following: Plug the charging cable to your computer or UL certified wall adapter. Align the contacts of the tracker with the charging cable and plug it in making sure it snaps securely. Your tracker should start charging.
Regards,
Will
Best Answer11-10-2022 07:36
11-10-2022 07:36
@neill065, it's a shame fitibit doesn't realise their latest firmware is causing so much issue especially the excessive battery drain. I had a good run with mine from April 2017 to March 2021 until it updated to the latest firmware and bricked it. Because it was out of warranty I figured why not take the chance and replace the battery myself. I managed to replace the battery and it still came up with the same issue. What does this tell you fitbit? Giving us instructions to turn off this and that defeats the purpose. Why don't you just listen to us and roll back to the previous firmware or make a new firmware. Is it too hard to ask? Or is it your way to make it eol so that we stupidity go buy a new one. If this is the case you won't be getting my business any more.
