10-11-2021
16:17
11:59
CindyMFitbit
10-11-2021
16:17
11:59
CindyMFitbit
Having the same issue!
Moderator Edit: Clarified subject and label
10-14-2021 12:00
10-14-2021 12:00
Welcome to the Community Forums @Thommie68.
I'm sorry to hear about the difficulties you experienced with your Charge 3 screen brightness. I recommend making sure that the Sleep Mode option is disabled on your Fitbit device. When the sleep mode setting is on:
To turn off Sleep mode: Press and hold the button, and swipe left to access the quick settings screen. Tap Sleep to turn it on or off. When you turn off the setting, the icon appears dim with a line through it.
Additionally, I suggest trying a restart as described here.
On a side note, I've moved your post to this thread so we can keep our forums organized.
Hope this helps.
