01-28-2020
11:16
17:42
01-28-2020
11:16
17:42
My Fitbit Charge 3 is stuck on the screen which shows distance and calories burned. The clock is keeping correct time, and the distance does change as I walk, but tapping does not change the screen to show steps, etc. Swiping doesn't work either.
01-28-2020 12:40
01-28-2020 12:40
I would possibly suggest restarting your Charge 3, as explained in the sidebar on the main screen labeled "Restarting Charge 3"
Best Answer01-28-2020 12:40
01-28-2020 12:40
Best Answer01-29-2020 04:30
01-29-2020 04:30
Best Answer01-30-2020 10:47
01-30-2020 10:47
It's great to welcome you, @lblair02 and @SkullBurner, thanks for the input.
I am glad to hear that the instructions provided by our friend worked. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up! 🙂
Best Answer08-07-2020 19:41
08-07-2020 19:41
Where is the sidebar?
Best Answer08-07-2020 19:47
08-07-2020 19:47
how to restart charger 3?
