07-12-2019
12:47
05:02
WilsonFitbit
07-12-2019
12:47
05:02
WilsonFitbit
The heartbeat monitor starting glitching during my run this morning and after my workout I noticed it was vibrating constantly.
The screen is flickering between the screen wake notifications menu and the time/ home screen. I would say it is flickering more then 2-3 times per second.
07-16-2019 10:47 - edited 07-16-2019 10:47
Welcome to the Community Forums @Merlin01! Thanks for reporting the odd behavior of your Charge 3's screen. Also, thanks for restarting your device.
Since the restart provided didn't work, I've gone ahead and escalated your case to our Support Team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions. ![]()
Let me know if you need further assistance.
Best Answer07-12-2019 12:48
07-12-2019 12:48
I forgot to mention I tried to reset the Fitbit while on the charger but that did not help out at all.
07-12-2019 14:48
07-12-2019 14:48
Welcome to the Community Forums @JeffClark1983! Thanks for letting me know about your Charge 3's behavior.
I appreciate all the efforts in trying to fix this issue. Since the restart you tried didn't work, I've gone ahead and escalated your case to our Support Team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
Let me know if there's anything else I may do to assist you with.
07-12-2019 19:27
07-12-2019 19:27
Having same issue with Charge 3 which I purchased only 6 months ago. Hopefully Customer Support will have some feedback soon as I'm seeing other users reporting the same problem.
07-13-2019 08:34
07-13-2019 08:34
Welcome to the Community Forums @CraigMartin3184! If your Charge 3 won't stop vibrating and keeps switching between the screens, I recommend restarting it by following the instructions provided in the help article: How do I restart my Fitbit device?
Thank you for the thorough feedback for the Fitbit devices. Please know that we provide feedback to our team based on community posts and we are always working on improving our devices and overall environment based on that feedback.
Give this a go and let me know the outcome, I'll be around.
Best Answer07-13-2019 08:36
07-13-2019 08:36
Best Answer07-13-2019 11:06
07-13-2019 11:06
Best Answer07-13-2019 11:12
07-13-2019 11:12
07-14-2019 05:47
07-14-2019 05:47
Thank You
Best Answer07-14-2019 19:05
07-14-2019 19:05
I'm having the same rapid flickering between screens and won't stop vibrating problem. The battery is also running out every day. As a result, my stats are not showing correctly in the app. I have tried the 8 second restart and the 15 second long restart. I have tried all of the suggestions in the help forums. Nothing helps for very long because I have to restart it numerous times every day now that I have to charge it every day. The only reason I upgraded to the Charge 3 is because my Charge 2 screen broke. I was happy with the Charge 3 until this super annoying problem started recently. With the number of people reporting the same problem, I don't even want to own a Fitbit anymore. Please provide me with a rapid, permanent solution to this mess.
07-15-2019 09:23 - edited 07-15-2019 09:24
Hello there @JeffClark1983! I am sorry to hear that you are going through this situation. Thanks so much for all the steps you've tried so far to solve the issue.
As mentioned above, I've created a support case so our Support Team can continue assisting you. Please don't miss to check your inbox, someone will be in touch with you very soon.
Hey there @CraigMartin3184! I'm very glad to hear that our team helped you to solve the issue.
Welcome to the Community Forums @travellingfood! I totally understand how you feel. I appreciate your feedback for the Fitbit Charge 3.
I was about to create a support case on your behalf, but I've seen you contacted our Support Team after posting here and that they have helped you with this. ![]()
Let me know if you have any questions present.
Best Answer07-15-2019 11:05
07-15-2019 11:05
I have the same problem with the screen flickering back and forth and also heart rate not working. Reset several times but did not solve the problem.
Best Answer07-17-2019 05:38
07-17-2019 05:38
Now my Charge 3 appears completely dead. Won’t even turn on. Please update Support. Will wait to hear from them. Thanks
08-18-2019 09:11
08-18-2019 09:11
My Charge 3 is flickering through screens nonstop. I have tried resetting it to no avail. What do I do now? I have had it for less than a year! 😞
08-18-2019 09:16
08-18-2019 09:16
Best Answer08-25-2019 21:54
08-25-2019 21:54
Tonight my charge 3 started flickering between screens and I’ve tried the restart but it just gives me the occasional smiley face, then goes blank before starting to flicker between screens again! Help! I haven’t even used it to swim yet!
08-25-2019 21:54
Mine too!
Best Answer08-25-2019 23:51
08-25-2019 23:51
I am having the same problem. I tried the restart an it made it worse. Doesn’t do anything at the moment
Best Answer08-26-2019 03:35
08-26-2019 03:35
How do I contact customer support. My charge 3 is dead
