02-09-2019
11:19
11:25
02-09-2019
11:19
11:25
My charge 3 screen seems to be locked. It will charge and sync, but only the clock face will show. Does not change to see heart rate or receive text messages. Any suggestions?
02-09-2019 11:45
02-09-2019 11:45
Mine is doing the same thing! Is there a reset somewhere?
02-09-2019 12:28
02-09-2019 12:28
Mine is doing the same thing, started yesterday. Like it's stuck on the clock face, even when charging.
02-09-2019 12:35
02-09-2019 12:35
02-09-2019 12:48 - edited 02-09-2019 12:53
I am having the same issue. I have had an issue in the past with a blank screen and was told to attach to the charger to reset....I think that is ridiculous, there is obviously an issue that needs to be addressed . I am going to try to restart now.
Best Answer02-09-2019 13:00
02-09-2019 13:00
Thank you !! It worked for me to !!![]()
Best Answer02-09-2019 13:03
02-09-2019 13:03
02-09-2019 13:11
02-09-2019 13:11
Best Answer02-10-2019 17:29
02-10-2019 17:29
02-19-2019 07:05
02-19-2019 07:05
Your solution of plugging in and holding the button for about 8 seconds worked. It changed to a progress line which got stuck. I had to do it again and the smiley face appeared. Thanks.
03-19-2019 10:08
03-19-2019 10:08
I recently received a new charge 3 free of charge from fitbit because it wouldn't charge. New one worked fine until today (only a month or so out). Now the screen is locked on time face. It won't charge and my app is telling me to connect to the internet (which I'm already connected to).
Thoughts?
Best Answer03-19-2019 18:46
03-19-2019 18:46
03-19-2019 19:22
03-19-2019 19:22
Best Answer02-03-2020 17:01
02-03-2020 17:01
Mine also. Holding side button while in charge dock took it out of Clock only face.
FITBIT needs to explain why or fix it.
Felark
Best Answer03-01-2020 22:22
03-01-2020 22:22
i had to try a few times as well.. but i first tried holding the button with my fingernail, then when i held it with my whole finger it worked. i think it MIGHT sense it or something... thats probably what happened to you.
04-17-2020 05:11
04-17-2020 05:11
Thanks for the info. I did exactly what you said and my screen is once again functioning properly.👍😎
