07-24-2020
06:47
13:20
07-24-2020
06:47
13:20
Fit fit screen only shows half of all data including clock face. The right hand side of clock face and all data is missing. Everything is working perfectly otherwise. It records steps swimming distance etc.
Update:
**ahem** it only shows half the clock
Moderator edit: merged replies and subject for clarity
Hi @Stowie, it's nice to see you again in our Community Forums.
I am sorry to hear your Charge 3 only shows half clock face and data. I appreciate the additional details and I am here to help. I recommend doing the following:
Additionally, I recommend checking if your Fitbit app is updated to the latest version as updates come with new features and bug fixes: How do I update the Fitbit app?
Keep me posted on the outcome. I'll be around if you have any additional questions.
Best Answer07-27-2020 04:59 - last edited on 07-27-2020 12:23 by LiliyaFitbit
Wow thank you very much for your prompt response. This is a true mystery to me. It started when I put it in to recharge and I took it out and it was only half a screen. Shortly after that I contacted you. Less than a day later it’s a full screen again which lasted less than 24 hours and then half disappeared again. BUT now it’s been full screen for almost a week and a half. So I’m not not performIng those recommendation, however I’m taking a screenshot in case this happens again so I have a way to fix it permanently. Puzzling isn’t it. Thanks
Sent from my iPhone
Hi @Stowie, thank you for your reply.
I am glad to hear the issue is resolved now, I appreciate the additional details. I hope you continue enjoying the Fitbit experience and working on your goals.
In case you have some spare time, I would like to invite you to visit our Discussions board where you can share your experiences, make new friends and create new topics.
Keep on visiting the forums. Happy stepping!
