03-27-2019
15:18
11:08
03-27-2019
15:18
11:08
I've had my Fitbit Charge 3 for almost 4 months with relatively no issues. Although earlier today I noticed it was on a low charge, so when I got back to my dorm and plugged it in, the face didn't change as I've grown accustomed to.
I was confused and plugged it in and out multiple times to no avail. Next, I looked up potential ways to fix it and saw to hold the side button for 8 seconds whilst the Fitbit is being charged. I tried this as well, and nothing happened.
It's stuck on the screen with a low charge symbol in the top left. The time, steps, and beat counter still work fine. If possible I'd love a solution. My Fitbit still works just fine, but I have that low charge symbol in the top left permanently it seems like so I won't know when it's low again. Perhaps let it die and see what will happen then?
03-28-2019
04:51
10:41
03-28-2019
04:51
10:41
A warm welcome to the Community @Xevoro.
Thanks for troubleshooting this display issue by yourself. If your tracker is stuck, I recommend performing a long restart by doing the following:
Let me know the outcome. ![]()
02-07-2020 08:54
02-07-2020 08:54
Thank you, thank you for this! I before bed always set my alarm, turn the screen brightness to dim, and make sure the screen wake is off at night. In the morning I turn it all back to normal, but today it wouldn't work. It would slide up, down, etc. to any of the other screens and when I pressed the side button there was no reaction. I found this, tried it, and my FitBit works perfectly now! Thank you!
Best Answer02-07-2020 09:57
02-07-2020 09:57
Thank you for this. My screen was frozen too. I followed the procedure and it is now unlocked. 👍👍👍
02-07-2020 10:02
02-07-2020 10:02
Hi,
My charge 3 screen is blank. It’s been happening on and off for about a week, but cannot get it to work at all today. I’ve tried the plug it in, press the button, smiley face and unplug, telling etc. This has not worked. Still blank screen. It’s not even 12 months old!!
Help please....
02-23-2020 18:15
02-23-2020 18:15
This worked great! Thanks so much!
Best Answer02-23-2020 19:17
02-23-2020 19:17
Thank you for this info!
I had the same issue but fixed it by taking slightly different steps:
1) hold button down for 15 seconds
2) attach to charger
03-06-2020 09:56
03-06-2020 09:56
This worked for me. Thanks!
Best Answer03-09-2020 14:13
03-09-2020 14:13
Worked perfectly, thanks.
Best Answer03-17-2020 17:14
03-17-2020 17:14
I have the same issue and instead of replacing the unit (I’ve had it less than 6 months) they want me to spend MORE money and buy another one rather than replacing the dud that they sold me.
03-17-2020 18:42
03-17-2020 18:42
Try this, it worked for me
Hope it helps!
Best Answer03-18-2020 04:17
03-18-2020 04:17
Have you talked to customer services? I did online chat, and they have resolved my issue and have been super helpful. Mine was nearly 12 months old....
Best Answer03-18-2020 04:18
03-18-2020 04:18
Thanks, but mine would never reset or fully shut down.... Fitbit have resolved this now though!!
Best Answer03-27-2020 16:41
03-27-2020 16:41
This happened to me, too. The suggested fix didn't work, but changing the clock interface did! I'd suggest trying that.
04-14-2020 09:30
04-14-2020 09:30
This happened to my charge 3 too. Did what you said, and it worked!
Best Answer04-14-2020 11:39
04-14-2020 11:39
Best Answer06-17-2020 17:54
06-17-2020 17:54
Thank You, that worked!
Best Answer06-17-2020 19:10
07-05-2020 10:26
07-05-2020 10:26
Thanks for sharing this trick. It worked great for me.
Best Answer08-10-2020 16:19
08-10-2020 16:19
Thanks. Changing my clock face worked great! I was able to fix it with my phone using the app. I didn't have to wait till I got home to put it on the charger and count. Click on your picture(account), your device, and clock faces. Choose a clock and hopefully it will work for you too.
