01-31-2021
10:36
02:42
01-31-2021
10:36
02:42
My charge 3 screen started dimming this week. Now the screen is black. I tried turning it off then on. And using the charging cable. It won't charge and I feel the vibration. It's still taking note of steps and sleep and heartbeat etc. What else can I do?
01-31-2021 23:59
01-31-2021 23:59
Fitbit's advice for those having this problem is at Check here for help with Charge 3 screen issues - Fitbit Community
The restart is suggested in the hope that it's just a software glitch but if that's not working it's likely to be a hardware failure. Customer Support can check your warranty status and advise on your options.
Best Answer01-31-2021 23:59
01-31-2021 23:59
