06-04-2023
03:01
10:59
06-04-2023
03:01
10:59
Hi!
I have a FitBit Charge 3 but I have noticed that the screen is dim. I have checked that the settings are correct, ie it is on bright etc.
Something seems to be wrong with the screen as the dimness is the same across the whole screen. It is more dim on the outskirts of the screen.
Can this be fixed?
Thanks!
06-04-2023 11:00
06-04-2023 11:00
Hello there, @putyourgunson. Thanks for stopping by in the Fitbit Community Forums and trying to troubleshoot the issue with your Charge 3 before reaching out.
In addition to the steps you've done, please restart your Charge 3 as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Best Answer06-05-2023 02:15
06-05-2023 02:15
Thank you!
I tried this and the screen is still dim.
