11-25-2021
13:17
16:16
EdsonFitbit
11-25-2021
13:17
16:16
EdsonFitbit
My Charge 3 is screen is unresponsive, however there seems to be an issue with the button which is preventing a restart while plugged into the power cradle.
The button vibrates when pressed, but seems to register a de-press (another vibration which matches that a transient button press).
The depress vibration anytime within 0 to 2 secs of the initial button press.
This seems to prevent the traditional button press restart while powered, no matter how long the button is held.
Otherwise, the fitbit is fully synched, and is recording activity.
I have also attempted to restore the screen through changing the screen display through the app, but have had no luck.
11-29-2021 16:15
11-29-2021 16:15
Welcome to the Fitbit Community, @padraig82.
I'm sorry to hear about the difficulties you experienced with your Fitbit Charge 3. Thank you for trying to get them resolved before contacting us.
Please try cleaning around the button of your Tracker with a toothpick to remove any dust or moisture that may be affecting its functionality. Then, try once again to restart your Charge 3 by following these steps. In addition, you can try to perform a long restart:
Hope this helps.
Best Answer12-03-2021 19:37
12-03-2021 19:37
Thank you for the reply.
Unfortunately, the fitbit charge 3 has an inductive button, contained in the case, rather than a physical button with gaps in which debris could become lodged.
The button issues can't be solved with a toothpick.
Best Answer12-04-2021 05:43
12-04-2021 05:43
I just chatted with someone from Fitbit and got cut off. However, when I tried doing the hard restart, after pressing and holding for 15 seconds I wasn't able to hear/feel the specified vibrations. I went through the steps regardless, but I still wasn't able to see the screen after. Please advise if there are any next steps.
Best Answer12-05-2021 13:35
12-05-2021 13:35
Welcome to the Fitbit Community, @lamial.
Thank you for the information provided @padraig82 @lamial.
The best way to get help for this problem is to chat with us online or give us a call. Please click here to get connected.
Have a nice day.
Best Answer12-05-2021 14:06
12-05-2021 14:06
I am having the exact same issue. Item is almost 3 years old. Appears that Fitbit are trying to force me to buy a new one. It still records my steps, and I sometimes get a faint glimmer of a screen, but can't move between them. I spend 4 hours yesterday googling ways to reset and fix - to no avail. Feeling quite annoyed!!
Best Answer12-06-2021 12:05
12-06-2021 12:05
Thank you for visiting the Fitbit Community, @KayEvvans.
In addition to the instructions shared above, you can try to change the clock face of your Fitbit device:
- From the Today tab in the Fitbit app, tap your profile picture > Charge 3
tile.
- Tap Clock Faces.
- Browse the available clock faces. Tap a clock face to see a detailed view.
- Tap Install to add the clock face to Charge 3.
If you have followed our recommendations without luck, you can reach out Customer Support.
See you around.
