02-01-2020
17:31
17:16
02-01-2020
17:31
17:16
Good evening! My Charge 3 is behind by 1 hour. I have tried everything but I cannot get the time to be correct. I have deleted my Fitbit and downloaded the program again. I have rebooted the Fitbit Charge 3 but still the Fitbit is an hour behind! Any suggestions would be appreciated! Thank you!
If it is exactly one hour, it sounds like a time zone issue. Check the time zone. If it is set right, try changing it to something wrong, sync, then change back to correct, and sync again.
07:10
08:21
02-02-2020
07:10
08:21
Welcome to the Community, @mistieg2 and @JohnnyRow, thanks for the input.
I appreciate all the efforts in trying to fix this time issue. I was able to see here that our friend @JohnnyRow provided some instructions in order to fix this problem. Was this the answer you were looking for? If it was, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Now, if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out.
Best AnswerThank you, JohnnyRow & AlejandraFitbit - I changed to Alaska time for a little while and then back to my time and I am still 1 hour behind! 😞
07:41
08:06
02-03-2020
07:41
08:06
Thanks for the update, @mistieg2.
I am glad to hear that your time issue has been resolved. If there is anything else we can help you with, do not hesitate to post it.
Happy stepping! 🙂
