02-01-2020
03:07
17:16
02-01-2020
03:07
17:16
Its only been 5 months and it just happened today when i seemed to notice that white stripes appeared . Its been working properly and charging properly , so i dont know why these appear.
Please help and send me solution for this problen
@Bookworm05 @Sassygg This sounds like a hardware issue and not something a restart will fix. Please contact Fitbit Customer Support for further resolutions.
Best of luck!
Best AnswerI have the same issue however my screen has also reduced in size so is a grey rectangle in the middle of the screen rather than filling the screen. It also seems like my battery is draining really fast. 5% in about 15 minutes. It had run flat last night so put it on to charge this morning to full. Tried plugging it back in to reset and it had already lost 5%. The reset did nothing.
Best Answer@Bookworm05 @Sassygg This sounds like a hardware issue and not something a restart will fix. Please contact Fitbit Customer Support for further resolutions.
Best of luck!
Best AnswerWhats the customer service number?
Best AnswerIn singapore?
Best Answer@Bookworm05 I don't know what it is for Singapore, perhaps try a google search?
You can also contact customer support using this link.
