04-23-2020
02:27
12:03
04-23-2020
02:27
12:03
Hi, I have been using Charge 3 for a while now and i am very disappointed to notice that tracking is incorrect. Like my steps, i would not take a step and it will add 100. Sleep tracking is also completely wrong. Like last night i went to bed at 10:30 but on tracking it showed from 8pm. Has anyone noticed these flaws?
Welcome to the Community, @BA5.
I am sorry for the delay in response. For tips about improving accuracy, I recommend checking the help article: How accurate are Fitbit devices?.
Several things can affect the number of steps your Fitbit device records, including where you place the device, if you wear it on your dominant or non-dominant hand, and your stride length. If you're pushing a stroller or shopping cart, try putting your device in your pocket or use GPS to record your activity, if possible.
If it still seems like your device is undercounting or overcounting steps, try a step test. While you perform your step test, make sure you:
-Walk at a normal pace
-Don’t hold anything in your hands
-Put your arms down at your sides, swinging naturally
-Count 1 step for each foot
-To avoid getting an additional step when you bring your feet together, after you reach 100 steps:
Here’s the step test:
Now about the sleep, you can try the following:
Let me know the outcome. 🙂
