03-21-2021 05:27 - last edited on 03-22-2021 17:36 by LiliyaFitbit
About 3 weeks ago Fitbit was down for a couple of hours - first time it ever happened to me. And this is my forth Fitbit. Since then i find that my Fitbit doesn’t update very quickly in the morning. None of my stats are updated and if I try to go into a Category, it doesn’t respond and then when it does open, the stats are not updated. It takes a minute or two and then updates. This has never happened before. I checked with a friend who has a Charge 4 and the same thing is happening to her. I have reset my Charge a couple of times since this happened and it has made no difference. What is going on and when are you going to fix it? I love my Fitbit & just want it back to normal.
Welcome to the Fitbit Community, @LJL99.
Thanks for the details shared in your post and for already trying to resolve the issue. I recommend trying the following:
If you're having difficulty with syncing, please check our complete tips here.
Hope this helps!
