10-10-2018 12:51 - last edited on 12-24-2020 15:05 by LiliyaFitbit
my fitbit 3 stopped syncing with my, iphone 6 it won’t connect to my bluetooth, tried deleting the app , switching bluetooth off/on resetting won’t work , anything else i can do ? synced for 1 day then stopped connecting to bluetooth
10-10-2018 14:32
10-10-2018 14:32
Having the same issue with my Charge 3 on the iPhone X. I’m assuming this is a universal issue with the software? Can anyone advise?
TIA
10-10-2018 14:35
10-10-2018 14:35
10-10-2018 16:58
10-10-2018 16:58
@Witchynoodles @Lvm96_ It's great to see you in the Fitbit Community.
I'm sorry to hear about the difficulties you experienced to sync your new Fitbit Charge 3. This problem should be resolved by restarting your tracker. After performing this procedure, please manually sync your Charge 3 while it’s still in the charger.
If you have any questions, please let us know.
10-10-2018 17:10
10-10-2018 17:10
Will there be a proper fix for this release within 2 weeks? I don’t want a tracker that needs to be plugged in to sync (LOL) but can only return for 2 weeks.
10-11-2018 10:28 - edited 10-11-2018 10:28
This worked for me thanks iPhone X stopped syncing after few days.
10-11-2018 14:14
10-11-2018 14:14
@Zobertbui @CJBuffaloNY Thanks for visiting the Fitbit Community.
This issue will definitely be fixed soon. Once any update be available it will be communicated as soon as possible. Thanks for your patience in the meantime.
Keep on stepping.
12-05-2018 15:32
12-05-2018 15:32
My Fitbit Charge 3 is failing ti synch with my iphone 6. I've tried the pressing down the side button for 8 seconds on charge and synching phone - no joy. Tried deleting app and reinstalling app - no joy. I've tried everything it seems but no joy. Can anyone advise....I'm failing to be impressed with what I had high hopes for.
12-05-2018 15:33
12-05-2018 15:33
My fitbit 3 stopped syncing with my, iphone 6 it won’t connect to my bluetooth, tried deleting the app , switching bluetooth off/on resetting won’t work , anything else i can do ? synced for 1 day then stopped connecting to bluetooth
12-05-2018 18:17 - edited 12-05-2018 18:17
I've tried all of these steps numerous times with no luck. It worked fine for the first few days and now will only sync with my iPad Pro.
12-06-2018 13:14
12-06-2018 13:14
12-06-2018 16:57
12-06-2018 16:57
Hi @Alih_mirza @melet @Witchynoodles, thanks for your comments.
Besides the regular restart, you can also perform a long restart by following these steps:
Hope this helps. Let me know how it goes.
12-13-2018 13:53
12-13-2018 13:53
I’ve restarted charge 3, I’ve removed app on iPhone 8 & reinstalled. I’ve shut off Bluetooth and turned it back on, I’ve shut off my phone and restarted. I’ve reset and rebooted my charge. It won’t manually sync. I’ve revoked my device and relived in. Nothing is working. I took charge off for 5 days in November and now I cannot get it to sync anything. HELP
12-13-2018 16:47
12-13-2018 16:47
@Shellbell23 Welcome to the Fitbit Community.
Thank you for the time you spent trying to resolve the syncing issue. To further investigate this situation, I created a case with Customer Support. Please check out your inbox on the next days. They will let you know how to proceed.
Keep on stepping.
12-13-2018 19:52
12-13-2018 19:52
12-16-2018 18:39
12-16-2018 18:39
@melet Thanks for the update.
I'm glad to hear that you have resolved the syncing issue, thank you for letting me know.
On another note, you are welcome to visit the Discussions board where you might find interesting topics to join.
Hope to see you more often in the Community.
03-01-2019 20:54
03-01-2019 20:54
Day 1 I got notifications on my Charge 3 for texts, but now it continuously disconnects from Bluetooth & I never get notifications anymore.
Whas going on? Brand new charge 3. It’s very frustrating to already have issues within 2 days
05-28-2020 08:45
05-28-2020 08:45
My Fitbit charge 3 has stopped syncing with my Iphone 6S Plus. Its worked fine since bought last July but stopped syncing in April this year. I've tried following the advice above and Im still having an issue. I tried uninstalling the app from my phone and reinstalling, I've removed the device from the app and am not now able to add it again. The app says its found the tracker and that its connecting to it but nothing happens even if i leave them next to each other for a couple of hours. The fitbit is attached to the charger as per your instructions but still no luck. I followed your instructions for restarting the tracker but when I press the button for 15 seconds the screen goes blank and then the smiley face comes up even before I let go of the button although your instructions say it shouldnt. No idea what to do next
07-20-2020 08:20
07-20-2020 08:20
No smiley face, just a progressive line.
