10-10-2018
09:05
15:47
10-10-2018
09:05
15:47
How do you return to the time
Hey there @Caroline67, it's nice to see you here! The home screen is the clock. On the clock:
On the Quick Settings screen:
If this is not what you're looking for, please give me more details so I can better assist you.
Keep me posted!
Best AnswerGot it figured out by reading another couple of posts- use the button on the left more than once until you get to where you want to go. Thanks!
Where on Charge 3 is “screen wake”? When I turn my wrist the clock does not show. The only way I can see the time is by tapping the screen twice. Always having to use two hands to see the time is ridiculous! Btw I have done a “reset” three times, no difference.
Best AnswerHi, I recently got a Fitbit Charge 3 and I have a problem with it. I tapped on the weather on my fitbit and now I can't seem to get off of it. I've tried tapping, double and triple tapping and holding down the button on the side but nothings happening. Please help?
Place your index finger on the left side of watch and thumb on the right - what no one is telling you is a quick squeeze of your index finger and thumb will cycle back up to the main screen. A press and hold of your index finger and thumb will bring you to settings.
So, it's quick squeeze to back out of stuff - didn't seem obvious when reading manual.
Best Answerset clock
Best Answeri have try every thing, but i cannot get the correct time
I have tried this and every other solution suggested here and still cannnot get back to seeing the time/date screen. If I just do nothing will it eventually return to that screen?
I am having the same issue. The back button worked for a while and now it doesn’t. Tried changing the clock face, tried charging and resetting....it won’t even reset- while charging or not charging.
